Upload Error
bubbles
Upload Error
Post by bubbles »
Hi everyone.
First post, I just received my unit a couple of days ago and finally got around to setting it up today.
Unfortunately I get the error below when trying to upload a sketch (any sketch).
I've had a good play around with the com port settings and the drivers appear to be installed ok. Changing the com port in the driver manager (and arduino IDE to match) doesn't fix it. Have tried 1, 3 and 4.
Couple of reinstalls don't seem to have helped. I've done 1 with the 1.03 library upgrade and 1 with the 1.02 version from the download.
Any help would greatly be appreciated.
Cheers.
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 6,804 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Jaco\AppData\Local\Temp\build2012703379118744043.tmp\InitialInternalMemory.cpp.hex:i
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         Copyright (c) 2000-2005 Brian Dean
         Using Port                    : \\.\COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude done.  Thank you.
bubbles
Re: Upload Error
Post by bubbles »
Oh FFS, talk about an own goal. Changed the board type and it worked as expected. 2 seconds after posting.
:D
Sebyte
Re: Upload Error
Post by Sebyte »
Don't feel bad, common problem!
