Don't use MH hours...
The wizard doesn't use those memory locations...
It uses the std lights schedule.
Can't download reef angel installer
Re: Can't download reef angel installer
but i cannot aslo control pwm of leds
whan i canhe it to any % nothing changes
i also tries client suit : 3 and the same issue
when it comes to programming i "always need help "
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
InternalMemory.OverheatTemp_write( 896 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.StandardHeater( Port3,240,250 );
ReefAngel.StandardFan( Port4,250,260 );
ReefAngel.StandardLights( Port7,14,0,20,0 );
ReefAngel.MHLights( Port8,16,0,18,0,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(14,0,20,0,15,40,15) );
ReefAngel.PWM.SetActinic( PWMParabola(14,0,20,0,50,80,50) );
ReefAngel.Portal( "redadeath" );
You need to choose internal memory path when generating your code through the wizard.
Its still not going to work from the phone...just my experience...if it does please lmk.
If it did his values in the app would have changed with no effect instead of reverting.
