wizard problem
Re: wizard problem
what i am running now on the actinic offset it bothe white and blue led
and the metal halide on standard day light schedule
and what i am trying to modify i having different offset for white and blue led
i hope you understand what i mean
when it comes to programming i "always need help "
Re: wizard problem
So do i have to add+60 to the code as i showed before
Re: wizard problem
CODE: SELECT ALL
ReefAngel.PWM.StandardActinic(InternalMemory.ActinicOffset_read()+60); // Parabola using actinic offset
Re: wizard problem
What if you do this:
ReefAngel.PWM.StandardActinic(120);
Re: wizard problem
Why 120 i just need it to start before white led with 60 minutes
Re: wizard problem
Here is my light system so u can imqgine what i am talking about
I have blue and white led and metal halide i need blue first then white then metal halide
- image.jpg (73.16 KiB) Viewed 4927 times
Re: wizard problem
ReefAngel.ActinicLights( Port7 ); // turn port 7 with actinic offset over standard lights schedule
ReefAngel.DelayedStartLights( Port8 ); // turn port 8 using standard lights schedule
ReefAngel.PWM.ActinicPWMParabola(120); // Parabola using actinic offset
ReefAngel.PWM.DaylightPWMParabola(InternalMemory.ActinicOffset_read()); // Parabola using actinic offset
Would this code work
Re: wizard problem
I try it doesnt work and both white and blue channels ignored my pwm settings
Re: wizard problem
This is what i needrimai wrote:Ahh..
So, you want mh on the standardlights and both actinic and daylight on the standardlights + offset?
Is that it?
Both AP and DP will dim together, right? Or you also want offset for AP and DP?
Offset for ap and offset for dp
Re: wizard problem
CODE: SELECT ALL
When i use this code the relay start at the time of the actinic offset and shut down at the end in the same time the ap pwm signals still works for additional hour while the relay is already been shutdown
Re: wizard problem
would you give me the code for that Roberto please
but it is ignoring my internal memory settings for % of starting parabola
Re: wizard problem
ReefAngel.StandardLights(Port7,60);
http://www.easte.net/RA/html/class_reef ... class.html
