reading the directions and i have gotten stuck on step 6 of loading your initial memory settings
it says to go to file-sketchbook-example codes and select initialinternalmemory..
when i go to file sketchbook a right arrow appears but there is nothing to pick
im using a mac if that matters... i have the tools board set as RA w/ optiboot
appreciate any advice....i have printed and read alot before unboxing but seem to be stuck here
Newbie here
Newbie here
You need to make sure to copy the arduino folder that comes with the Mac package to your Documents folder
- Contact:
Re: Newbie here
lnevo wrote:You need to make sure to copy the arduino folder that comes with the Mac package to your Documents folder
Re: Newbie here
Re: Newbie here
you pull them across the screen from left to right and drop them
