pc wont connect
Re: pc wont connect
Yes, it is correct...
COM3 is the serial port you will use to communicate with the controller.
Drivers are installed correctly.
Re: pc wont connect
So what am I doing wrong?
Sent from my EVO using Tapatalk 2
Re: pc wont connect
It doesn't say what's is connected just what port it is.
Re: pc wont connect
It already did.
Your USB-TTL cable drivers are already installed correctly.
Windows doesn't see the controller. It only sees the cable and you communicate to the controller through the cable.
It's a USB-TTL cable from FTDI: http://www.ftdichip.com/Products/Cables ... Serial.htm
Now, you need to upload your code. Either copy one of the existing ones, use one of the example codes or generate one with the wizard.
Re: pc wont connect
I've tried making a scetch with wizard and when I try and upload it I get a bunch of errors
Re: pc wont connect
Yes give me just I while
Re: pc wont connect
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
Relay Expansion Module
PH Expansion Module
Standard Menu
Binary sketch size: 29,270 bytes (of a 30,720 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM3 -b57600 -D -Uflash:w:C:\Users\NALOGS~1\AppData\Local\Temp\build1723728085333315681.tmp\sketch_apr19c.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv: 3 [33]
avrdude: stk500_getsync(): not in sync: resp=0x33
avrdude done. Thank you.
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
PH Expansion Module
Standard Menu
Re: pc wont connect
and here is the code
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,551,815 );
ReefAngel.StandardATO( Port2,60 );
ReefAngel.StandardLights( Port3,15,0,0,0 );
ReefAngel.WavemakerRandom( Port5,4,100 );
ReefAngel.WavemakerRandom( Port6,24,100 );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
int x,y;
// pH Expansion
// Relay Expansion
Re: pc wont connect
just the regular not the plus
Re: pc wont connect
Make sure you have Reef Angel controller w/ optiboot selected under Tools->Board
