Reef Angel Interface Freezing
mjstokes
Post by mjstokes »
Hi all, just got my Reef Angel a few days ago, and starting coding a function to turn my heater on/off based on temperature. It seems to be working great as my temperature has been very constant over the past 2 days, however, the screen on the RA freezes and will not allow me to do anything, even though it it still running it code correctly.
Here is my current code:
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit | Port8Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port5,760,765 );
Any help you could provide would be greatly appreciated! Thanks!
Re: Reef Angel Interface Freezing
It's most likely just the screen itself, since you mentioned that it continues to work.
PM for details on RMA.
mjstokes
Post by mjstokes »
Will do
mjstokes
Post by mjstokes »
I don't see a PM option, do I need a certain number of posts first?
pandimus
Post by pandimus »
I believe five.so say "ok thanks", and you should be there.
