coolbird wrote:rimai wrote:That may be related to the recent change on the firmware 4.00
I have not updated the wifi utility for that.
It requires a two step process as described in their manual and here:
http://www.rovingnetworks.com/FAQs/How_ ... y_versions
This update will also disable the WPS feature and enable the SoftAP with built-in webserver for config changes.
The internal webserver for config changes is awesome!!! Too bad they are sharing the same idle timer... We use timer of 3 seconds and it is not long enough to do anything.
I've been in touch with them and they said that more config options will be implemented, but there is no real timeframe for that.
enigma32 is working on a new type of remote connection, so let's see what he comes up with.
Ok then all it leaves me with the thought that I am doing something wrong when I am uploading the wifisetup code!!!
I reset the RA and the wifi, although the wifi was a bit of a problem, I tried the tera term method and the terminal just displayed what could best be described as jibberish, to make matters worse the reset button on the wifi adapter did not work, once pressed the adapter just continued to blink green slowly.
Once I had got everything reset and the RA back with the preloaded code I then ran the wifi utility as described here
http://forum.reefangel.com/viewtopic.php?f=15&t=345 and reprogrammed my adapter, this went smoothly and the software reported that it had successfully opened port 2000.
Then I removed the cable USB cable from the wifi adapter and connected to the RA and ran the arduino software to run the wifisetup template.
(This is where I start having problems: I modify the wifisetup to include my Auth Mode, Pass Phrase and SSID, then upload the code, plug in the adapter and press the joystick which then takes a few minutes but eventually the wifi starts to blink slowly green but the RA is then stuck at this point)
My question 2 questions are
When you load the wifisetup template it says "This code can be used to setup your wifi attachment and associate it on your wireless network.
Although, the easiest way and prefered method is to use the wifi graphical setup utility."
What is this "wifi graphical setup utility" and where do I find it, I know about all the utilities for setting up the wifi adapter but this one eludes me!
Second question:
Also in the wifisetup template it states "Once you have it setup, you will want to reload your INO file or generate a new one"
Is there not a way of using the relevant code from the wifisetup including my pass prhrase etc with the code generated by the wizard and just upload all at the same time or am I missing something?
I would like to thank all those that have taken the time and trouble to help with this problem, not to mention displayed amazing patience.
Regards
Dave
