Help!!!!Heater not kicking on
SaltyGXP
Post by SaltyGXP »
For some reason my heater isn't kicking on. its set to kick on at 77.5 and off at 78 on port 5 here is my code. I'm using the wizard with the internal memory option and then putting my custom code in.
#define DateTextColor COLOR_CLAY
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, 15, 4 , " Ratliff's Reef ");
ReefAngel.LCD.DrawDate( 6, 112);
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.MoonLights( Port4 );
ReefAngel.StandardHeater( Port5 );
ReefAngel.Relay.DelayedOn( Port6 );
if (hour()>=10 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 50% +/- 20% on sync mode
else if (hour()>=16 && hour()<19)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,5000,true) );
else if (hour()>=19 && hour()<22)
ReefAngel.PWM.SetDaylight( SineMode(20,45,30,true) );
ReefAngel.PWM.SetDaylight( LongPulseMode(15,35,120,true) );
ReefAngel.Portal( "saltygxp" );
Re: Help!!!!Heater not kicking on
Code looks good.
Have you tried hard code settings?
SaltyGXP
Post by SaltyGXP »
rimai wrote:Code looks good.
no............I just hooked it up today its been sitting the past week because of work. I haven't had anytime to look anything else up and learn other than my jebao coding. anyway you can show me what i need to add?
Replace this:
With this:
ReefAngel.StandardHeater( Port5,775,780 );
SaltyGXP
Post by SaltyGXP »
rimai wrote:Replace this:
With this:
Thank you very much for the help sir. :mrgreen:
