Wifi Install help
kirkwood
Wifi Install help
Post by kirkwood »
I went through the Wifi install without any problems. After the install it said that port forwarding had been completed.
My portal and droid app aren't recognizing the ip address that I'm entering.
What did I miss?
dbmet
Wifi Install help
Post by dbmet »
Did you check to make sure port 2000 is open ?
Wifi Install help
Also what ip are you entering? If you enter the one the wifi utility gives you that wont work on the portal...
kirkwood
Re: Wifi Install help
Post by kirkwood »
lnevo wrote:Also what ip are you entering? If you enter the one the wifi utility gives you that wont work on the portal...
That's what I was using. What should I be using?
dbmet
Post by dbmet »
Use the one this site gives you..
http://whatismyipaddress.com/
