Do I need Static IP Address?
kirkwood
Re: Do I need Static IP Address?
Post by kirkwood »
I followed the directions for the WiFi Utility Application.
http://forum.reefangel.com/viewtopic.php?f=15&t=345
My router automatically completed the port forwarding. I don't see anything mentioned about hard coding the RA IP address. How can I allow that to be dynamic?
Seems like it would already be dynamic since it changed with the power outage.
kirkwood
Post by kirkwood »
cosmith71 wrote:Seems like it would already be dynamic since it changed with the power outage.
I have not confirmed yet that the external IP is dynamic. At this time I can only confirm that the local IP for the RA is dynamic becaues that changed. I will have to wait till this evening when I get home from work to address the problem.
Depending on your router you can use IP reservations that are based on MAC address. When the router sees the MAC address as active...it will only allow that specific device to be the IP you reserve. Pretty handy little trick for a lot of things if you have a large home network like me.
I would bet that the external IP is dynamic. Most residental ones are. The static ones are expensive!
DrewPalmer04 wrote:Depending on your router you can use IP reservations that are based on MAC address. When the router sees the MAC address as active...it will only allow that specific device to be the IP you reserve. Pretty handy little trick for a lot of things if you have a large home network like me.
Yep, that's the way mine works, too.
Only way around ISP IP changes is to:
1: call and ask if static is available/cost
2: dyndns.com
Also it really just depends on how "important" remote access is...
For me. if the ISP IP changes. I lose connection remotely (because obviously the IP I'm using is wrong) so I go home later that night. Find my WAN IP and change it to be correct. No Biggy. BTW, this has only happened once in 2 years or so and that's because my ISP was bought out :)
kirkwood
Post by kirkwood »
DrewPalmer04 wrote:Also it really just depends on how "important" remote access is...
I live in the City of Atlanta and for some reason I think our power grid sucks. We usually lose power during bad storms. Remote access is of critical importance to me so I want to make sure I retain remote access whenever I lose power.
I got myself a free account with no-ip so if the dynami external IP is an issue, it seems I can correct that for free. Is there any difference between a port reservation and a static IP?
Static IP is from your ISP. A port reservation is like a static IP on your home network. I.e., the Reef Angel always gets 192.168.1.x.
Another way to think about it is:
A device says "this IS my IP address router" STATIC
Versus: "What is my IP address router?" DHCP
kirkwood
Post by kirkwood »
thanks to all for the assistance. I got the issue corrected. When I got home this evening I checked my external IP and it did NOT change. Next step I set an address reservation for the RA as .7 which is what I used during wifi setup. That still didn't correct the issue. So I checked the RA port and it was closed. I did the port fwding in my router setup and that corrected the issue. I guess the port closed during the power outage.
