How to setup your wifi attachment
Re: How to setup your wifi attachment
To make sure that it's putting out data that the portal or the apps will understand you can always do
http://your.internal.ip.address:2000/r99
and you should see an XML document which has all of the data that the portal or app would show.
Then once you know that's working you can work on the port forwarding to let the portal reach down into your ReefAngel to get live data and to let you change settings on your RA using the portal functions.
I've tried setting up port forwarding on my router but for some reason it's not working. I don't have a static IP address and can't get one, does this mean I can't port forward? I've never had this problem when i've needed to forward ports for games before.
Also overnight when nothing has changed at all, the blue lights on the wifi have started flashing. I've been asleep all night, no one has touched it so why has it randomly stopped working?
You don't need static ip. Portal detects your ip in real time. If you know how to port forward it seems like you don't have your wifi connected well to your router. I had trouble keeping mine connected to my fios actiontec router. You don't have one of those, do you?tom_swell wrote:I've tried setting up port forwarding on my router but for some reason it's not working. I don't have a static IP address and can't get one, does this mean I can't port forward? I've never had this problem when i've needed to forward ports for games before.
Hmm no I have a netgear dgn2200v3. I'm not entirely sure, now i can't see the port forwarding exemption in my router settings and when i try and test to see if the port is open i get told it is closed. But when i try adding in port forwarding on my router it says that the rule already exists :\
So i plugged in the wifi attachment to my pc and ran the Utility as it clearly wasn't working. I seem to be getting a lot of Unknown errors and being told to take the plug in and out. Then when it does work and i try and connect i get this:
It will say it is associated and authenticated but my ip will still be 0.0.0.0 and despite only the green light slowly flashing it wont be connected and i can't see it on my network.
The other half the time i try and get it to work it fails to associate and authenticate and connect.
Any ideas?
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM4
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM4
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM4
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 1052 10 config
< 25 88548 3 wifly-GSX-441-r1057
< 26 1052 10 user
< 145 Free, Boot=25, Backup=2
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s **********
< set w s **********
< AOK
< <4.41>
> set w p **************
< set w p **************
< AOK
< <4.41>
< set w k 00000000000000000000000000
< AOK
< <4.41>
> set ftp address 198.175.253.161
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=NETGEAR36
< Chan=6
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router NETGEAR DGN2200v3 Router
Port 2000 is now being forwarded to 0.0.0.0
Any ideas?
Just thought I'd leave a final update here incase anyone else has similar problems in the future. Thanks a lot to Roberto's help we managed to nail down that the wifi adapter couldn't achieve a solid connection to my wireless network as the router was too far away. After purchasing and setting up a wireless extender the problem was fixed near instantly and now i have access to the portal features and can control things via my phone
Now to figure out how to connect from outside my wifi network :\
i think im having the same problem as everyone else. i can access my controller on my home wifi while connected but as soon as disable wifi on my android the app says connection timed out or connection refused. i also cant access my controller on the portal either. ive been reading all the different posts and nothing is making sense. i have port forwarding set up for 2000, and also have a static ip set up so it doesnt get a new one. can someone please help me. also when i open the app and look at the settings the "home" ip address is different then the one that was set up when i used the wifi program. i tried changing it but it tells me connection time out. i am at my witts end with this. i got the wifi attachment under the assumption i could access my controller anywhere in the world as im military thats the reason i went with the reef angel. can someone please help me with this.
Have you checked the site that sees if the port is open or not? Sounds like the port forwarding is not working still. You should use your home IP when you're on your network and your external (check www.whatsmyip.org) or RA DDNS while you're away. If port forwarding is working then you should be able to use the external IP on your home network as well.
If your IP starts with 191 or 192 then that's your internal IP and won't work outside of your home network. You'd need to use your external IP. If you open up the portal web page it's near the top right.
ok i dont know what the external ip address is. can someone break this down sesame street style? im not super tech saavy. i open my portal and theres no ip address in the top right corner. its just blank. also reset my router several time, re did port forward several times, took off all firewalls, re programmed the wifi attachment, gave it a static ip address, and contacted the manufacturer and ISP, and still cant access outside my home wifi. im getting really frustrated. i put in the wifi attachment ip xxx.xxx.x.x:2000/r99 and it works it shows me my authentication name and some numbers so the port forwarding is working on wifi, i just can figure out how to attach to my portal or how to access on my phone app using cell service. i live near oxnard,ca if someone wants to help.... but im officially lost... someone please break this down for me lol
also when i use the website to test the port it says closed but i can access it with my wifi. im using a netgear wndr3700v2. and i just downgraded my software to the original and still didnt work.
and also i used the wifi wizard to program the wifi attachment and the arduino wizard to program the controller. am i missing anything? i didnt write any of my code so am i missing something in the code? i set up my authentication on the android app but will that put that in the code for me? or do i have to do that myself? also when i use my wifi setup utility it doesnt show any of the information that someone else posted. ive also tried uninstallin and re installing the reef angel software.
We'll get you working, no worries. If you go to www.whatsmyip.org it will show you your external ip address. Port forwarding is only for when your not on wifi. Some ISPs do block ports. Do they own your router? You may need to call them for support. If its working at home then your ok with the wifi attachment firmware and setup. As far as authentication if you set that up in the wizard then you'll need it setup in the android app and in the portal. If you did not add authentication in the wizard the. Don't set it up elsewhere... Can you post your code? There should be a line in there that has your portal username.
Hey, I just recently set mine up this month too. If you're attempting to use the internal IP address (usually starts with 192.168.x.x) then it won't work outside of the network on the app. I realized that after reading several post. I used that whatsmyip.org and used that IP address and now everything works.
Oh, as far as the portal, same thing, use the IP address you get from whatsmyip.org and followed by ":2000"
hope that helps, noob to noob
So I am lost. I setup using the wizard wrote down the address given and it also said it setup the port forwarding. The green light on the wifi is slowly blinking green and there is no blue light so I am assuming it is connected. I tried connected using the windows phone app I get that the port is connected but not the controller. Where do I start to trouble shoot this. Also where does the "whats your ip address" come into play? It is different than the address the wizard gave me.Should I be using that one instead and go back through the wizards for the wifi and controller?
Thanks in advance!
Thanks in advance!
If you're connecting on your local wifi network then you use the IP that the wizard gave you. If you are using from your cell phone network or out of your house, then you use the address that what's your ip address gives.
I went back through the wizards and got it going at least when I am home. Now I the issues is the temp and ph ports wont read anything
I am having some issues still with accessing the RA while not at home. It is fine when I am at home cell links up as it should. Here is the code Can you see any issues that would affect this.
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.CustomLabels[1]="Heater2";
ReefAngel.CustomLabels[2]="ReturnPump";
ReefAngel.CustomLabels[3]="Jebao dc return";
ReefAngel.CustomLabels[4]="Skimmer";
ReefAngel.CustomLabels[5]="reactor";
ReefAngel.CustomLabels[6]="spare";
ReefAngel.CustomLabels[7]="spare";
ReefAngel.StandardHeater( Port1,765,796 );
ReefAngel.StandardHeater( Port2,755,795 );
ReefAngel.Portal( "hodge1995" );
ReefAngel.DDNS( "192.xxx.xxx.47:2000" ); // Your DDNS is hodge1995-192.xxx.xxx.47:2000.myreefangel.com
Still having issues. Any ideas? I have tried the ddns that is given by the wizard while setting up also have went to "whats my ip" and tried that one.
Did you setup port forwarding in your router?
Does it show port 200 open when you check your port?
He means port 2000, not 200.rimai wrote:Did you setup port forwarding in your router?
When I click the link it has the address and then say port 80 when you hit check it says port 80 is closed. I put 200 and 2000 in the port box hit check and says they are all closed. According to the wizard when I set it up , it said it had automatically opened port 2000
If port 2000 says closed, port forwarding is still required to be setup in your router.
Thanks for the reply, I will try to do that when I get home
- cody.sheridan-2008
Hi,
I was having issues with the setup, where the connection would only occasionally work on my home network with a couldn't connect message coming up. I hadn't approached port forwarding.
Because of this and the antiquated modem/router I had, I have changed my cable modem to a cg3100D-2 modem/router combo. I am having a hard time as it won't produce an ip, I am just getting 0.0.0.0:2000 . The green light is flashing.
Can anyone tell me what to do?
Cheers
Cody
Cody
Can anyone suggest a fix for the above to get it working? Need more info?
Cheers
Cody
Cody
You have DHCP false... is your router running DHCP? Otherwise you'll need to set a static IP on the wifi module. Also make sure your router is set for AES-2 I believe and no spaces in the password.
Thanks Inevo, I will take a look tomorrow (Australia based)
Cheers
Cody
Cody
Hi Inevo,lnevo wrote:You have DHCP false... is your router running DHCP? Otherwise you'll need to set a static IP on the wifi module. Also make sure your router is set for AES-2 I believe and no spaces in the password.
Sorry for the delay.
I just installed another modem/router my internet provider (telstra) sent out . It is a Netgear C6300BD.
I am having the same issue as before.
Have logged in and had a look, seems to run DHCP?
Also the security key stuff is solid numbers and see below:
How do I set a static IP on the wifi module?
Cheers
Cody
Cody
