How to setup your wifi attachment
Re: How to setup your wifi attachment
I get the same result if use:
SSID: XXXXXXX
PHASPHRASE/PASSKEY: yyyyyyyyyy (the other pass refered as Guest Password(PSK) above 10 letters and numbers)
SSID: XXXXXXX
I wonder if it has to do with my utility. Sebyte mentioned he was unable to get it going with this app either.
Can you try Dave's app?
https://github.com/davemolton/Graphical ... ves/master
Hi Roberto, I tried that again (was the first soft I used before the newer one).
I still cant avoid teh green/blue blinking and the 0.0.0.:2000
There is another number instead of 2000 (I saw someone else used one different )?
I also tried at another pc , downloaded daves app, same result
Just a shot in the dark - do you have a MAC address filter on your router?
Hi Dave, there is a tab in the router with this info:
MAC adress control
Enable MAC filtering: disable
Access Rule for registered MAC adress: allow
MAC filtering table (up to 32 stations) (a table with ID, MAC address with six positions each row, all in 00)
In the LAN settings of the Router it says:
LAN/WLAN MAC: 00-1C-DF-BF-68-2D
IP address: 192.168.2.1
Subnet mask: 255.255.255.0
DHCP server: enabled
MAC adress control
Hi, I have uninstalled all the software and starting to reinstall all again, lets see what happens ...
Hi, reinstalled all but I get the same (now the COM6 port was assigned)
*Wifi* Status
Associated: true
Authenticated: false
DHCP: false
Mode: WPA2
IP adress and port: 0.0.0.0:2000 (remember that I used the "Restore Factory Settings" before, and since then the IP changed to this)
and the blue and green leds blinks
Any idea?
*Wifi* Status
Associated: true
DHCP: false
Mode: WPA2
Any idea?
Hi Roberto/Dave
I disabled the router Security Mode, and then I was able to set the IP to the wifi attachment and get it working (Client 2.2, and Reef Angel Controller Web Server).
I will try to reset the Security mode again and reset the wifi
I'm very happy to announce that I was able to implement UPnP on the wifi setup utility.
So, this utility is now capable of setting up port forwarding on any UPnP capable router that is compatible with the UPnPLib Java library.
I've updated the original thread with the addition.
That's pretty cool. That can help out a lot.rimai wrote:I'm very happy to announce that I was able to implement UPnP on the wifi setup utility.
I am unable to to get an IP address on the Wi-Fi attatchment. It looks like the same issue as above where I get an IP address of 0.0.0.0:2000, Associated: True, Athenticated: true, DHCP: false, Mode: WPA2.
I made sure that the encryption is set to WPA2 PSK AES on my router. I tried to use the Tera Term too but the terminal does will not display any information from the Wifi Attatchment. Can you please assist me? Thanks
When using tera term, you need to type $$$ within 1s to enter into config mode, did you do that?
Just to make sure, you do have DHCP enabled in your router, correct?
Looks like I need to find a copy of the wifi test script, it's not in my install where the walkthrough says it is. Is there a copy I could download?
Try downloading the new installer and install the software again.
Compile error:
Class twowire does not contain somethign "read" etc. Dunno laptop is downstairs. Any ideas?
That's mismatched libraries with the new Arduino IDE.
To clean up your system and have everything fresh, make sure to uninstall any previous version of the RA installer. Then delete the Arduino folder inside Documents folder.
Install the new one.
Ok, it finally uploaded, and now my RA screen reads:
No internal memory found.
Good!!!
You are in the right path
Now, all you need to do is load an internal memory file and you should be good to go
Go to menu “File->Sketchbook->Example Codes” and select “InitialInternalMemory”
http://www.reefangel.com/Support.Loadin ... tings.ashx
Hmm so that means I shouldn't have pulled it all apart and unscrewed it from the wall...
In any case, it's starting to appear as if everything got deleted. I did that step, and now it told me I could upload an INO file. So I went to the backup I made (instead of deleting) the old one I was running before, and it won't compile, I assume because the new libraries don't match since I reinstalled everything.
Hmm...
Hmm...
I'm trying to reset my wifi adapter and i'm having trouble doing it, i tried the new app for setting wifi and i get the false statement on blue led blinks, i tried the older utility and i get this:
CMD
set w a 4
AOK
<2.32> set w p xxxxxxx
AOK
<2.32> set w s xxxxxx
AOK
<2.32> set i l 2000
AOK
<2.32> save
Storing in config
*BAD CONFIG*
<2.32> reboot
*Reboot*
What should i do?? i Know is not my router cause it was working this morning, i was just trying to set with the new utility to see if i lose connection less often.
CMD
set w a 4
AOK
AOK
AOK
<2.32> set i l 2000
AOK
<2.32> save
Storing in config
*BAD CONFIG*
<2.32> reboot
*Reboot*
I tried now, but it didn't work, still getting false statement on the new utility, and on the old one everything seen ok, but adapter don't connect to router.
I can't find my ssid
For some reason it doesn't work
Both SSID and password is case sensitive.
I also recommend WPA2-PSK with AES encryption.
I've seen some of the other security options giving problems in the past.
Also, does either the SSID or password have a space in it?
I have two different routers I tried them both and yes one does have a space in the name
Does my router need to be plugged in to my computer?
No, it does not need to be plugged into the computer.
Try replacing the space with a $ sign.
