How to setup your wifi attachment
Dboyfx
Re: How to setup your wifi attachment
Post by Dboyfx »
I am unable to to get an IP address on the Wi-Fi attatchment. It looks like the same issue as above where I get an IP address of 0.0.0.0:2000, Associated: True, Athenticated: true, DHCP: false, Mode: WPA2.
I made sure that the encryption is set to WPA2 PSK AES on my router. I tried to use the Tera Term too but the terminal does will not display any information from the Wifi Attatchment. Can you please assist me? Thanks
When using tera term, you need to type $$$ within 1s to enter into config mode, did you do that?
Just to make sure, you do have DHCP enabled in your router, correct?
anathema
Post by anathema »
Looks like I need to find a copy of the wifi test script, it's not in my install where the walkthrough says it is. Is there a copy I could download?
Try downloading the new installer and install the software again.
anathema
Post by anathema »
Compile error:
Class twowire does not contain somethign "read" etc. Dunno laptop is downstairs. Any ideas?
That's mismatched libraries with the new Arduino IDE.
To clean up your system and have everything fresh, make sure to uninstall any previous version of the RA installer. Then delete the Arduino folder inside Documents folder.
Install the new one.
anathema
Post by anathema »
Ok, it finally uploaded, and now my RA screen reads:
No internal memory found.
Good!!!
You are in the right path :)
Now, all you need to do is load an internal memory file and you should be good to go :)
Go to menu “File->Sketchbook->Example Codes” and select “InitialInternalMemory”
http://www.reefangel.com/Support.Loadin ... tings.ashx
anathema
Post by anathema »
Hmm so that means I shouldn't have pulled it all apart and unscrewed it from the wall... :(
anathema
Post by anathema »
In any case, it's starting to appear as if everything got deleted. I did that step, and now it told me I could upload an INO file. So I went to the backup I made (instead of deleting) the old one I was running before, and it won't compile, I assume because the new libraries don't match since I reinstalled everything.
Hmm...
symon_say
Post by symon_say »
I'm trying to reset my wifi adapter and i'm having trouble doing it, i tried the new app for setting wifi and i get the false statement on blue led blinks, i tried the older utility and i get this:
CMD
set w a 4
AOK
<2.32> set w p xxxxxxx
AOK
<2.32> set w s xxxxxx
AOK
<2.32> set i l 2000
AOK
<2.32> save
Storing in config
*BAD CONFIG*
<2.32> reboot
*Reboot*
What should i do?? i Know is not my router cause it was working this morning, i was just trying to set with the new utility to see if i lose connection less often.
Did you try the reset to factory settings button?
symon_say
Post by symon_say »
I tried now, but it didn't work, still getting false statement on the new utility, and on the old one everything seen ok, but adapter don't connect to router.
mad28gnc@yahoo.com
Post by mad28gnc@yahoo.com »
I can't find my ssid
It's the wireless network name
mad28gnc@yahoo.com
For some reason it doesn't work
Both SSID and password is case sensitive.
I also recommend WPA2-PSK with AES encryption.
I've seen some of the other security options giving problems in the past.
Also, does either the SSID or password have a space in it?
mad28gnc@yahoo.com
I have two different routers I tried them both and yes one does have a space in the name
mad28gnc@yahoo.com
Does my router need to be plugged in to my computer?
No, it does not need to be plugged into the computer.
Try replacing the space with a $ sign.
mason dixon
Post by mason dixon »
How do I upload the wifi test code to the reef angel?
I have a 6 pin usb/ttl cable but the input on the reef angel is 8 pin?
I also have a ttl cable that is 6 pin female on one side and 8 pin female on the other?
thanks
The USB-TTL cable can be used to upload codes to RA and also to setup the wifi attachment.
The 6pin-8pin is to be used when you want to connect RA to the wifi attachment.
Black wire is always to the right-most pin. Please check the manual for instructions on how to connect.
cody.sheridan-2008
Post by cody.sheridan-2008 »
Hi there,
With the 2nd type of connection, will it work if there is no passphrase? I am not sure why it would but it does nothing once I click "setup wifi attachment" just leaves black. I have talked to my master (father) and it is all to hard to put one on to try :roll:
I am getting to this point and then nothing. :?:
wifi utility 1.png (63.35 KiB) Viewed 22132 times
Cheers
Cody
I don't think it would work with no password
cody.sheridan-2008
yeah typed i a random bunch of letters and it did something but obviously didn't work. here comes the next 6 months battling to get one lol
Cheers
Cody
cody.sheridan-2008
rimai wrote:I don't think it would work with no password
Hey roberto,
The wifi attachment will work if you have no password you just need to put a space in the box.
Cheers
Cody
Cool :)
Thanks for sharing.
cgonser
Post by cgonser »
I so far have had a sucessful install until I go to type the IP in the address bar, then I get no connection. Set up went well, have only a green light blinking, but no connection. Any advice?
If you have a green blinking light then it should be good. Check in your router and see what ip address was assigned.
cgonser
Post by cgonser »
lnevo wrote:If you have a green blinking light then it should be good. Check in your router and see what ip address was assigned.
no clue how to do that! I copied the address the set up wizzard gave me...?
