How to setup your wifi attachment
AlanM
Re: How to setup your wifi attachment
Post by AlanM »
rimai wrote:Did you setup port forwarding in your router?
Does it show port 200 open when you check your port?
He means port 2000, not 200.
hodge1995
Post by hodge1995 »
When I click the link it has the address and then say port 80 when you hit check it says port 80 is closed. I put 200 and 2000 in the port box hit check and says they are all closed. According to the wizard when I set it up , it said it had automatically opened port 2000
If port 2000 says closed, port forwarding is still required to be setup in your router.
hodge1995
Post by hodge1995 »
Thanks for the reply, I will try to do that when I get home
cody.sheridan-2008
Post by cody.sheridan-2008 »
Hi,
I was having issues with the setup, where the connection would only occasionally work on my home network with a couldn't connect message coming up. I hadn't approached port forwarding.
Because of this and the antiquated modem/router I had, I have changed my cable modem to a cg3100D-2 modem/router combo. I am having a hard time as it won't produce an ip, I am just getting 0.0.0.0:2000 . The green light is flashing.
RAWIFI IP.png (40.45 KiB) Viewed 8068 times
Can anyone tell me what to do?
Cheers
Cody
cody.sheridan-2008
Can anyone suggest a fix for the above to get it working? Need more info?
Cheers
Cody
You have DHCP false... is your router running DHCP? Otherwise you'll need to set a static IP on the wifi module. Also make sure your router is set for AES-2 I believe and no spaces in the password.
cody.sheridan-2008
Thanks Inevo, I will take a look tomorrow :) (Australia based)
Cheers
Cody
cody.sheridan-2008
lnevo wrote:You have DHCP false... is your router running DHCP? Otherwise you'll need to set a static IP on the wifi module. Also make sure your router is set for AES-2 I believe and no spaces in the password.
Hi Inevo,
Sorry for the delay.
I just installed another modem/router my internet provider (telstra) sent out :roll: . It is a Netgear C6300BD.
I am having the same issue as before.
Have logged in and had a look, seems to run DHCP?
Also the security key stuff is solid numbers and see below:
How do I set a static IP on the wifi module?
Cheers
Cody
Is the blue led on the wifi attachment blinking?
cody.sheridan-2008
Hi Rimai,
No the green LED is the only one blinking (slowly).
Cheers
Cody
Cheers
Cody
That means your unit is already connect to your router.
Just check the connected devices in your router and you should the wifi attachment as one of them.
cody.sheridan-2008
Hi Rimai,
Yes I just checked and it is there:
Also did a ping test which worked:
I'm still having no luck with the ip - http://192.168.0.11/wifi (IE and Chrome)
Not sure what to do, looking forward to hearing your advice.
Thanks in advance
Regards
Cody
Cheers
Cody
Is the cable from the head unit to the wifi attachment looking to be good?
Is it a RA+?
cody.sheridan-2008
Yes all seems in good nick. Also yes it is a RA+
Cheers
Cody
Can you ping the wifi attachment from your computer instead of using the router tools?
cody.sheridan-2008
rimai wrote:Can you ping the wifi attachment from your computer instead of using the router tools?
Cheers
Cody
What is the ip address on your PC? Are you sure you are in the the same network?
cody.sheridan-2008
I'll have to check later, but yes certain I am in the same network. No neighbours here so we only have one network avaliable.
Cheers
Cody
cody.sheridan-2008
Hey Rimai,
Sorry for the delay, have been quite busy.
Seem to have gotten it working on my phone while I am in my network. Couple of weird things are happening though.
- My router/modem is putting out 2 networks 'Telstra1B6E' and 'Sherray'. Sherray is our old network from 2 modems/routers ago, so not sure why it is still around.
- I setup the module on the 'Sherray' network, hey presto it's working. I can't access it outside of my network but it is accessible on both the 'Telstra1B6E' and the 'Sherray' networks, but only when the wifi module is connected to 'Sherray'.
Anyway, it is working in my network now which is a big step forward. How do I get it working on my phone when I'm out?
Regards
Cody
Cheers
Cody
Sounds like you still have that router in there and you probably have two routers, which is complicating things a bit for you.
Echo5delta16
Post by Echo5delta16 »
Sooo frustrated... I did everything as i was supposed to from research here. i get to the part where i have to make it work with outside of my home network and nothing i see people saying that i should see. Meaning i dont see what people are telling me i should see. but it may be because they didnt explain how to get to that part.
Echo5delta16
Is it working on your wifi network?
If so, you need to setup port forwarding in your router.
Echo5delta16
rimai wrote:Is it working on your wifi network?
it WAS connecting to my router but now with trying all of these tips it wont even connect now. i plug it in now the blue light stays flashing.
i think its time to sell
slm222
Post by slm222 »
double post
slm222
Post by slm222 »
ok. I am able to hit the Reef Angel Controller Webserve from the public ip address http://24.170.42.205:2000/ .
Below is the code I uploaded. But all I get on the reef angel wifi unit is a green blinking light....help :?:
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.AddWifi(); // Add Wifi
    ReefAngel.FeedingModePorts = Port2Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
    // Define labels for 2014 LCD screen
    //box0
    ReefAngel.CustomLabels[0]="T5HO";
    ReefAngel.CustomLabels[2]="FugeLight";
    ReefAngel.CustomLabels[3]="Heater";
    ReefAngel.CustomLabels[4]="ScrubLight";
    ReefAngel.CustomLabels[5]="Kalk_Mixer";
    ReefAngel.CustomLabels[6]="Kalk_ATO";
    ReefAngel.CustomLabels[7]="RO_ATO";
    //lowers minimum speed for DC pump
    InternalMemory.DCPumpThreshold_write(0);
    //gives random sopmething to randomize against
     randomSeed(now()/SECS_PER_DAY);
    ReefAngel.ShowInterface(); //wifi
    ReefAngel.MHLights( Port1,12,30,14,30,5 ); //t5ho
    ReefAngel.MHLights( Port2,7,0,22,0,5  );  //skimmer
    ReefAngel.StandardLights( Port3,18,0,10,0 ); //fugelight
    ReefAngel.StandardHeater( Port4,785,788 ); //heater
    ReefAngel.StandardLights( Port5,18,0,10,0 ); //scrubber light
    ReefAngel.DosingPumpRepeat( Port6,0,240,25 ); // kalk mixing every 6 hours for 25 seconds
    ////// Wave Pattern Code Start
    //Hardcode minimum speed of DC pumps
    ReefAngel.DCPump.Threshold=0;
    static int rmode;
    byte modes[] = { ReefCrest, NutrientTransport, TidalSwell, Lagoon, Else, ReefCrest, Else };
    changeMode=false;
    static unsigned long feeding;
    // after feed mode Continue NTM for the 60 minutes
    if (now()-feeding<1800) {
    ReefAngel.DCPump.Mode=Else;
    //7am to 9am - wake up from night mode
    else  if (hour()>=7 && hour()<9){
    ReefAngel.DCPump.Duration=350;
    ReefAngel.DCPump.Mode=Sine;
    ReefAngel.DCPump.Speed=50;
    //9am to 10am - ramp up to random
    else  if (hour()>=9 && hour()<10){
    ReefAngel.DCPump.Mode=Lagoon;
    ReefAngel.DCPump.Speed=60;
    //10am to 6pm - Random
    else if (hour()>=10 && hour()<18) {
    ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
    ReefAngel.DCPump.Speed=70;
    //6pm to 7pm - slow down from random
    else  if (hour()>=18 && hour()<19){
    //7pm to 9pm - slow down to night mode
    else  if (hour()>=19 && hour()<21){
    // Night mode
    else  {
    ReefAngel.DCPump.Duration=450;
    ReefAngel.DCPump.Speed=40;
    ////// Wave Pattern Code End
    ////// ATO RO and Kalk Settings
if ((hour()>18 || hour()<9) && (ReefAngel.Params.PH < 822))
    ReefAngel.SingleATO( true,Port7,600,0 );   //  Sump switch. Kalk schedule 6pm - 7am if pH < 8.25  If ATO/Kalk runs for 10 minutes=600 seconds, then shut off.
    ReefAngel.Relay.Off(Port8);
    ReefAngel.SingleATO( true,Port8,500,0 );   //  Sump switch.  If ATO/RoDi runs for 8.20 minutes=480 seconds, then shut off.
    ReefAngel.Relay.Off(Port7);
    ////// End ATO RO and Kalk Settings
If you are able to access the internal webserver you are all set.
Green light means you are connected to your WiFi network.
It is not supposed to do anything else.
slm222
Post by slm222 »
rimai wrote:If you are able to access the internal webserver you are all set.
when I upload the wifi sketch I lose all my current code. how can I set up the reef angel and keep my code?
You are already all set. You don't need the wifi sketch. Your wifi attachment is already setup and connected to your network.
