How to setup your wifi attachment
PostPosted: Fri May 01, 2015 4:27 pm
Hi Rimai,
No the green LED is the only one blinking (slowly).
Cheers
Cody
Cheers
Cody
PostPosted: Fri May 01, 2015 9:05 pm
That means your unit is already connect to your router.
Just check the connected devices in your router and you should the wifi attachment as one of them.
PostPosted: Fri May 01, 2015 11:59 pm
Hi Rimai,
Yes I just checked and it is there:
Also did a ping test which worked:
I'm still having no luck with the ip - http://192.168.0.11/wifi (IE and Chrome)
Not sure what to do, looking forward to hearing your advice.
Thanks in advance
Regards
Cody
Cheers
Cody
PostPosted: Sun May 03, 2015 9:17 am
Is the cable from the head unit to the wifi attachment looking to be good?
Is it a RA+?
PostPosted: Sun May 03, 2015 1:31 pm
Yes all seems in good nick. Also yes it is a RA+
Cheers
Cody
PostPosted: Sun May 03, 2015 5:05 pm
Can you ping the wifi attachment from your computer instead of using the router tools?
PostPosted: Sun May 03, 2015 6:02 pm
rimai wrote:Can you ping the wifi attachment from your computer instead of using the router tools?
Cheers
Cody
PostPosted: Sun May 03, 2015 6:07 pm
What is the ip address on your PC? Are you sure you are in the the same network?
PostPosted: Mon May 04, 2015 4:03 am
I'll have to check later, but yes certain I am in the same network. No neighbours here so we only have one network avaliable.
Cheers
Cody
PostPosted: Sun May 17, 2015 1:40 am
Hey Rimai,
Sorry for the delay, have been quite busy.
Seem to have gotten it working on my phone while I am in my network. Couple of weird things are happening though.
- My router/modem is putting out 2 networks 'Telstra1B6E' and 'Sherray'. Sherray is our old network from 2 modems/routers ago, so not sure why it is still around.
- I setup the module on the 'Sherray' network, hey presto it's working. I can't access it outside of my network but it is accessible on both the 'Telstra1B6E' and the 'Sherray' networks, but only when the wifi module is connected to 'Sherray'.
Anyway, it is working in my network now which is a big step forward. How do I get it working on my phone when I'm out?
Regards
Cody
Cheers
Cody
Return to For New Members
Users browsing this forum: Google [Bot] and 3 guests
