Newbie with questions
tommy2fast
Post by tommy2fast »
Hi,
my name is Thomas and i come from Germany.I want to go with ReefAngel because i want to controll 3x Jebaos WP40.
First : which set should i take ?
i think .ReefAngel plus ...but with analog or pwm?What do you prefer?Also the dimming modul..which must i take for the Jebaos?PWM or analog?
I hope you can help :(
Thomas
Re: Newbie with questions
You can mix and match. Pwm is cheaper. Jaebo can use either. I highly recommend the plus.
tommy2fast
Hi,
thanks.if i am going to mix,i only need the Jebao cables to work?For both dimming systems?(analog and pwm).
is it possible to work with 3 pumps,and every pump has its own program/modus?
2 pumps work equal and another one works as wavebox. Is that possible?
thanks,
Thomas
The libraries currently have support built in to control many pumps but with only 2 modes. Sync/Anti-Sync. You could manually setup control for the 3rd. You could in theory run 8 jaebo's :)
All you need is cable.
tommy2fast
Great ;)
Thomas
