"Error Uploading" whenever trying to upload
oconnellp
Post by oconnellp »
I have seen multiple users complain of this issue, but I haven't seen a fix yet.
I am trying to upload custom code using the wizard, but I get this message every time I attempt to upload:
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 25,122 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -V -Uflash:w:C:\Users\Paul\AppData\Local\Temp\build4166232450658356248.tmp\InitialInternalMemory.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude done. Thank you.
I have a ReefAngel Plus and I have Arduino set to "ReefAngel Plus Controller" and "COM3". I have tested using the other controller board settings, but they don't work either.
I have tried using different USP slots but I still get the same result.
I have the USP cable connected just as it shows in the manual.
Can anyone help me figure out what's going on? This is getting very frustrating.
Paul
Re: "Error Uploading" whenever trying to upload
Does the controller reboot a few seconds after you hit upload?
oconnellp
Post by oconnellp »
Yes, it does.
oconnellp
Post by oconnellp »
Any idea what's going on?
oconnellp
Post by oconnellp »
Anyone?
One thing I noticed is that my cable is not wired exactly like to cable in the picture. The cable in the picture is wired Green - Yellow - Orange - Red - Brown - Black. My cable is wired Green - Orange - Yellow - Red - Brown - Black. Could this be what the issue is?
I may very well be.
The cable may have been assembled wrong. Can you switch?
oconnellp
Post by oconnellp »
I'm not quite sure how. Will I need any sort of crimping tool to do it?
No, no need to crimp anything. They are already crimped.
If you look at the black plastic connector, in the back, there are some latches that prevent the metal pin from sliding off. You can lift that latch and the pin will be free to slide off. Do this for both wires and reverse their order when you slide them back in.
oconnellp
Post by oconnellp »
Yep, that was the issue. I switched the wires into the correct sequence and it works fine now. Thanks for the help.
