White LCD screen....
baroutas
Post by baroutas »
ΗΙ!! Τoday, after 3 months (the RA it was out of work) i try to upload the preloaded code. After the uploading the RA looks dont work and the LCD is White. I must say tha i give power to the head unit whith the cable and not with relay box. Any ideas???
Re: White LCD screen....
Try uninstalling the Reef Angel Installer, download a fresh copy and install again.
Then upload the code once again.
baroutas
Post by baroutas »
I do, but nothing, do not upload the code. I try from second PC, upload the code but steel the LCD is dead- white (some time have color dot).
Was it working before you uploaded the code?
baroutas
Post by baroutas »
Yes it was! Now sow me that the code uploaded but LCD is White after uploading. What is the step to reboot the head unit?
Is it working with just the LCD white?
baroutas
Post by baroutas »
I dont know if working. I have not conect the head unit with relay box yet. I haw the RA disconected for 3-4 months and yesterday i try to upload ( with USB power cable) the preloaded code. from tha moment the LCD sceen is white and some times looks like has color pixels.
baroutas
Post by baroutas »
How can i chek the LCD screen? Is it possible that it didn't upload all the files the first time and stuk? If yes, can i reboot the head unit and how?
Also Ι conect the head unit with rellay box and i hear to open and close the rellay (probably works OK)!!
The controller is reset everytime you upload codes and erases the previous code.
Open Serial Monitor on Arduino and make sure you set 57600 baud and Both NL & CR.
Then, type this:
GET /mb336 HTTP
What do you get back?
baroutas
Post by baroutas »
Nothing...
baroutas
Post by baroutas »
Is it posible to hapen that:
Why doesn't my sketch start when I power up or reset the Arduino board?
Most likely because you are sending serial data to the board when it firsts turns on. During the first few seconds, the bootloader (a program pre-burned onto the chip on the board) listens for the computer to send it a new sketch to be uploaded to the board. After a few seconds without communication, the bootloader will time out and start the sketch that's already on the board. If you continue to send data to the bootloader, it will never time out and your sketch will never start. You'll either need to find a way to stop serial data from arriving for the first few seconds when the board powers (e.g. by enabling the chip that sends the data from within your setup() function) or burn your sketch onto the board with an external programmer, replacing the bootloader.
If there was a problem with bootloader, you wouldn't be able to upload any codes.
Which RA do you have?
baroutas
Post by baroutas »
I have the PWM.
I meant RA or RA+?
baroutas
Post by baroutas »
RA
baroutas
Post by baroutas »
If we disconnect the memory batery and reconnected, sould be work?
Ok, so try this code:
  ReefAngel.Init();
  Serial.println(InternalMemory.LCDID_read());
Upload, open Serial monitor and reboot RA. What do you see in the window?
baroutas
Post by baroutas »
I see "255".What means that?Also the LCD it remains white.
Can you take a photo of your LCD screen board?
I want to see what kind of screen you have.
baroutas
Post by baroutas »
baroutas
Post by baroutas »
255 means gen1 or gen2 screens, which you do have.
0 would be for the gen3 screen.
It does look like everything is normal. I don't know what else to try. I think your screen may just be bad.
baroutas
Post by baroutas »
Τhanks Roberto! I send you PM for details about the screen!
baroutas
Post by baroutas »
Today arive the new LCD screen (Robeto send me one)! I put them on the RA board and i plug it in the power. But steel the LCD was White :( .... :?: :?: :?: Is it polsibole the problem comes from RA board???
Follow the instructions here to update your controller to use gen3 screens:
http://forum.reefangel.com/viewtopic.php?f=2&t=3111
baroutas
Post by baroutas »
YES!!!!!!!It will be done!!!!Perfect!! You are the BIG ONE Roberto!!! Thanks.
