White LCD screen....
Re: White LCD screen....
Is it posible to hapen that:
Why doesn't my sketch start when I power up or reset the Arduino board?
Most likely because you are sending serial data to the board when it firsts turns on. During the first few seconds, the bootloader (a program pre-burned onto the chip on the board) listens for the computer to send it a new sketch to be uploaded to the board. After a few seconds without communication, the bootloader will time out and start the sketch that's already on the board. If you continue to send data to the bootloader, it will never time out and your sketch will never start. You'll either need to find a way to stop serial data from arriving for the first few seconds when the board powers (e.g. by enabling the chip that sends the data from within your setup() function) or burn your sketch onto the board with an external programmer, replacing the bootloader.
If there was a problem with bootloader, you wouldn't be able to upload any codes.
Which RA do you have?
If we disconnect the memory batery and reconnected, sould be work?
Ok, so try this code:
Upload, open Serial monitor and reboot RA. What do you see in the window?
ReefAngel.Init();
Serial.println(InternalMemory.LCDID_read());
I see "255".What means that?Also the LCD it remains white.
Can you take a photo of your LCD screen board?
I want to see what kind of screen you have.
255 means gen1 or gen2 screens, which you do have.
0 would be for the gen3 screen.
It does look like everything is normal. I don't know what else to try. I think your screen may just be bad.
Τhanks Roberto! I send you PM for details about the screen!
Today arive the new LCD screen (Robeto send me one)! I put them on the RA board and i plug it in the power. But steel the LCD was White .... Is it polsibole the problem comes from RA board???
Follow the instructions here to update your controller to use gen3 screens:
http://forum.reefangel.com/viewtopic.php?f=2&t=3111
YES!!!!!!!It will be done!!!!Perfect!! You are the BIG ONE Roberto!!! Thanks.
