I don't have the wifi adapter and was wondering if the reef angel unit keeps a log of values (pH changes, temp, dosing, etc) that I can see when I connect my pc to the ra unit via usb?
I tried using the Reef Angel Client software (3.0) and it will show the current stats but not a history of anything on the general tab or under the memory tab. I actually couldn't get the memory tab to show anything until I loaded the RAmemory.ini file I downloaded from somewhere on this forum; but then it was showing my info since all the values under the memory tab were either default info or someone else's...not sure what is wrong with that???
Anyway is there a way to see the history without having to have a wifi attachment?
