Time problem
smcglaughn
Time problem
Post by smcglaughn »
I noticed that the time and date on the head unit was wrong. It shows 1/2/00 3:21 Am. I tried uploading my latest code. Nothing changed. I uninstalled the RA installer and uploaded it again. Now when I try to upload my code I get the error uploading message. Any idea what I can do?
[quote]
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <AI.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <Salinity.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
  ReefAngel.WaterChangePorts= Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
  ReefAngel.Relay.On(Port1);
  ReefAngel.Relay.On(Port2);
  ReefAngel.Relay.On(Port3);
  ReefAngel.Relay.On(Port4);
  ReefAngel.Wavemaker(Port5,60);
  ReefAngel.Wavemaker(Port6,120);
  ReefAngel.StandardHeater(Port7,757,763);
//  ReefAngel.StandardLights(Port8,17,0,13,0);
  if ( (hour()>=2) && (hour()<5) ) {
ReefAngel.WaterLevelATO(Port8,450,85,90); // 450 seconds timeout, turn on at 85% and turn off at 90%
  int x,y;
  // Parameters
#if defined DisplayLEDPWM && ! defined RemoveAllLights
  ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
  ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
  // Salinity
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
  ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
  // Water Level
  ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,75, "WL:" );
  ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,75, ReefAngel.WaterLevel.GetLevel() );
  // Main Relay Box
  TempRelay &= ReefAngel.Relay.RelayMaskOff;
  TempRelay |= ReefAngel.Relay.RelayMaskOn;
  ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
  // Date and Time
Re: Time problem
Make sure the board and com port are correct.
smcglaughn
Re: Time problem
They are communicating. I don't get the com port error. The red light flashes when I plug up the cable and when it stars trying to upload.
Re: Time problem
What is the error you are getting?
smcglaughn
Re: Time problem
All it says is error uploading.
Re: Time problem
It should show the error in red at the bottom of the window.
smcglaughn
Re: Time problem
Maybe I'm looking in the wrong spot. The screen is split. The top is the code I'm loading. The bottom is what it's loading. In between the two screens. There is a message that says error uploading. The bottom box doesn't show an error that I see. I'll try it again this even I no when I get home and if it still won't update. I'll attach a screen shot.
smcglaughn
Re: Time problem
Here is what it says. This is at the bottom and its the closest thing I see to an error message.
avrdude: stk500v2_receivemessage() timeout
avrdude: stk500v2_getsync() timeout communicating with programmer
avrdude done Thank you
Re: Time problem
Do you have RA or RA+?
smcglaughn
Re: Time problem
I believe it the RA.
smcglaughn
Re: Time problem
It is the RA
Re: Time problem
Make sure to change the board to RA w/ optiboot and not RA+ under Tools->Board
smcglaughn
Re: Time problem
That worked as far as uploading to the controller. However it still didnt change the time on it?
Re: Time problem
It won't change the time.
You can do it easily with the portal or android app, but it looks like you don't have it.
Try adding this to your setup():
ReefAngel.AddDateTimeMenu();
The standard RA has limited memory, so it may not fit.
If your code gets too big with this, you will have to upload the preloaded code, change the time and upload your code again.
smcglaughn
Re: Time problem
Where does this go? code go?
Re: Time problem
your setup()
smcglaughn
Re: Time problem
Im not real sure where to put it. Can you look at my first entry and show me? Thanks
smcglaughn
Re: Time problem
Nevermind I got it. Thanks it worked.
smcglaughn
Re: Time problem
I have a new problem.Since I made the change and got the time corrected. The wavemakers do not turn off during feeding mode. I tried loading the older code back to the controller and it still does not work. Ive added the code below.
#include <Wire.h>
#include <Time.h>
#include <RA_ATO.h>
#include <LED.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <AI.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <PH.h>
  int x,y;
  // Parameters
  // Salinity
  // Water Level
  // Main Relay Box
  // Date and Time
Re: Time problem
Change this:
To this:
  ReefAngel.Wavemaker1(Port5,60);
  ReefAngel.Wavemaker2(Port6,120);
smcglaughn
Re: Time problem
When I deleted the old code and added the new code. I got the following error message. No matching function for call to ReefAngelClass::Wavemaker1(int,int)'
Re: Time problem
Damn... I totally misread your request.
Forget about the change... Sorry.
You need to add this:
ReefAngel.FeedingModePorts= Port5Bit | Port6Bit;
smcglaughn
Re: Time problem
Where do I put it?
smcglaughn
Re: Time problem
Nevermind. I think I got it. It seems to work. Thanks again.
smcglaughn
Re: Time problem
My water level expansion has quit working. It reads zeros on the screen and when I try to calibrate it . All zeros. I tried unplugging it and redownloading my programming. Neither had any effect. Any ideas or will it have to be replaced?
