Time problem
Re: Time problem
It is the RA
Re: Time problem
Make sure to change the board to RA w/ optiboot and not RA+ under Tools->Board
Re: Time problem
That worked as far as uploading to the controller. However it still didnt change the time on it?
Re: Time problem
It won't change the time.
You can do it easily with the portal or android app, but it looks like you don't have it.
Try adding this to your setup():
The standard RA has limited memory, so it may not fit.
If your code gets too big with this, you will have to upload the preloaded code, change the time and upload your code again.
ReefAngel.AddDateTimeMenu();
Re: Time problem
Where does this go? code go?
Re: Time problem
Im not real sure where to put it. Can you look at my first entry and show me? Thanks
Re: Time problem
Nevermind I got it. Thanks it worked.
Re: Time problem
I have a new problem.Since I made the change and got the time corrected. The wavemakers do not turn off during feeding mode. I tried loading the older code back to the controller and it still does not work. Ive added the code below.
ReefAngel.WaterChangePorts= Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
ReefAngel.Wavemaker(Port5,60);
ReefAngel.Wavemaker(Port6,120);
ReefAngel.StandardHeater(Port7,757,763);
// ReefAngel.StandardLights(Port8,17,0,13,0);
if ( (hour()>=2) && (hour()<5) ) {
ReefAngel.WaterLevelATO(Port8,450,85,90); // 450 seconds timeout, turn on at 85% and turn off at 90%
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,75, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,75, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
Re: Time problem
Change this:
To this:
ReefAngel.Wavemaker1(Port5,60);
ReefAngel.Wavemaker2(Port6,120);
Re: Time problem
When I deleted the old code and added the new code. I got the following error message. No matching function for call to ReefAngelClass::Wavemaker1(int,int)'
Re: Time problem
Damn... I totally misread your request.
Forget about the change... Sorry.
You need to add this:
ReefAngel.FeedingModePorts= Port5Bit | Port6Bit;
Re: Time problem
Where do I put it?
Re: Time problem
Nevermind. I think I got it. It seems to work. Thanks again.
Re: Time problem
My water level expansion has quit working. It reads zeros on the screen and when I try to calibrate it . All zeros. I tried unplugging it and redownloading my programming. Neither had any effect. Any ideas or will it have to be replaced?
