Naming ports?
Re: Naming ports?
So just for the record, if you wanted to make it easier for yourself, you could use this instead of what you wrote
ReefAngel.CustomLabels[Box1_Port1Label] = "Dosing";
Re: Naming ports?
Cool!!
Re: Naming ports?
ok, i know how to change the ports, but how do i change daylight channel and actinic channel to DC pump since i am using them for the WP40s?
this will be for the head unit not portal. Thanks
Re: Naming ports?
noooooooooooooooooooooo!!!!!!!
can i delete the things from the display that i don't use like the 2nd ph reading?
Re: Naming ports?
No. It's his psychological way of making you by the other stuff. Just so you don't see 0's there.
Re: Naming ports?
You can make your own custom screens if thats what you're after. From the portal, yeah... always been a sticking point... it's hard to argue with the logic of subliminal marketing
Re: Naming ports?
from the portal? that means i have to get the wifi module? but if i get the wifi module, i have to get the expansion module as well. you guys should sell refrigerators in antarctica. lol
Lee - the banner in your signature, is it a live feed? i seen banners where its updates continuously without having to refresh the page. i would seriously consider getting the wifi module if that can be done.
Re: Naming ports?
The banners are live feeds from the unit.
The WiFi module would not need the expansion module too.
It plugs directly into the head unit. Where you connect the upload cable.
Re: Naming ports?
It's a live feed, but it doesn't auto refresh. It's a jpg that gets generated when you load it.
Re: Naming ports?
I ran into an problem. Getting error code. This is when i am trying to change my reef angel display
'class ReefAngelClass' has no member named 'CustomLabels'
Re: Naming ports?
You may need to post your code. At least the line you trying to add..
Re: Naming ports?
Hmm not seeing any issue. I'll have to give it a run through the compiler later.
Re: Naming ports?
Custom Labels only work on the new 2014 screen. If you use custom main screen, it won't work.
Re: Naming ports?
So I have an outdated reef angel? How do I get the new screens?
Re: Naming ports?
No. There is some code that you add in to use the 2014 screen.
I thought I had it in my code, but I can't find it.
Re: Naming ports?
The code you are using is outdated. Look for your other post. I changed it for you.
http://forum.reefangel.com/viewtopic.php?p=41821#p41821
