Naming ports?
Sleepingtiger
Re: Naming ports?
Post by Sleepingtiger »
I ran into an problem. Getting error code. This is when i am trying to change my reef angel display
'class ReefAngelClass' has no member named 'CustomLabels'
Re: Naming ports?
You may need to post your code. At least the line you trying to add..
Sleepingtiger
Re: Naming ports?
thanks
sketch_oct04a.ino
(4.81 KiB) Downloaded 484 times
Re: Naming ports?
Hmm not seeing any issue. I'll have to give it a run through the compiler later.
Re: Naming ports?
Custom Labels only work on the new 2014 screen. If you use custom main screen, it won't work.
Sleepingtiger
Re: Naming ports?
So I have an outdated reef angel? How do I get the new screens?
Re: Naming ports?
No. There is some code that you add in to use the 2014 screen.
I thought I had it in my code, but I can't find it.
Re: Naming ports?
The code you are using is outdated. Look for your other post. I changed it for you.
http://forum.reefangel.com/viewtopic.php?p=41821#p41821
