Storm mode
Vernon
Storm mode
Post by Vernon »
Hi Guys
I need some help with something. I would like to create a mode mode which I can activate similar to feeding or water change mode. Is this possible ?
I want to activate a storm mode as a novelty function to show and wow guests when the come over. My idea is when I select storm mode, I want my Kessil A360W to go full actinic with lightining, I'd also like my DC return pumps output to increase with a reef crest mode, I'd like my Vortech to go wild as well and I'd want my ATO function to be disabled so my ATO doesn't refill the tank with the increased return pump flow...
This sounds ambitious I know : )
First things first, is it possible to create a new mode accessible via the RA plus menu ?
Re: Storm mode
Yes, we can create something like that.
In fact, there is already something like that created, except the Meanwell drivers are really not meant to flash that fast, so the effect is just ok at best.
I'm not so sure about the Kessils. We can try.
http://forum.reefangel.com/viewtopic.php?f=14&t=288
Post your code and we can add the stuff we need to get this working.
