New User Questions
howaboutme
Re: New User Questions
Post by howaboutme »
Ok, Roberto,
It reads 762 w/ no probe attached in both 7 and 10 and 509 when shorted. What does this tell you?
Jack
The board looks to be fine. That's the reading you should get. You will need a new probe though :(
howaboutme
OK. Thanks. Any explanation on why my initial calibration was giving me trouble? See a few posts up.
Sent from my Galaxy Nexus using Tapatalk
Jack
Hard to say now.
howaboutme
Haha..Okay, nice diplomatic answer....
Will get a new ph probe.
Jack
rossbryant1956
Post by rossbryant1956 »
Hey Jack, I'm in Montgomery Village and have some extra probes in stock. Let you have one for a good price. PM me.
Ross
RoscoesReefs
howaboutme
Ross, sent you a PM but for some reason it's stuck in the "outbox".....I assume I'm allowed to PM though I have seen other people request that function from Roberto...Hope it goes through.
Jack
rossbryant1956
got it. replied.
Messages stay in outbox till they are read :)
howaboutme
lnevo wrote:Messages stay in outbox till they are read :)
haha..okay..thinking too much about outlook. thanks!
Jack
howaboutme
rimai wrote:Use the controllertester code in the examples folder to test each port.
roberto..this is in regard to the post about relay #6 not shutting off during feed/wc mode..i did the controllertest code..flipped through it but wasn't sure what to look for. the outlet was on when i flipped to #6. is that what you're testing? thanks.
Jack
You can scroll through each port turning it on and off by moving the joystick. Look at the screen to see which port is turned on.
howaboutme
Yeah, I did that and everything seems to be okay for the test. #6 just won't turn off even though the code is correct. This is the 2nd time this happened. First time, the problem solved itself somehow w/o me doing anything.
Jack
Are you sure you are not overriding the relay port?
howaboutme
rimai wrote:Are you sure you are not overriding the relay port?
No, I am not sure. But I don't think so. I do nothing to the controller before I hit either the feeding or wc mode. I even re-uploaded the code last night to the controller and #6 still didn't recognize the mode. I am thinking tonight I will try to move the ph that's on #6 to an open outlet to test again.
How would I override the relay port? Since I am new I cannot rule that out inadvertently.
PS. I obtained a wifi module that I worked on briefly last night too. I have a few questions but will post a different thread so my questions won't get lost in this. Thanks.
Jack
