RF Expansion with the Vortech MP40W es
djtutt
Post by djtutt »
Once connected and programmed, the RF Expansion unit shows purple for Nutrient Transit Mode but the Vortech is green. Is the Vortech controller supposed to reflect the same mode that the RF Expansion is showing or do you ignore the Vortech controller's colors all together?
Re: RF Expansion with the Vortech MP40W es
Your vortech should not be green if its synced properly. Either orange white or turquoise. The color on the vortech will represent the mode its in.. Sync, anti-sync, or back wall you can hit mode to change it between those three...otherwise only the speed indicatir should change
djtutt
Post by djtutt »
Ok, I reprogrammed and now my Rf is blue in short pulse mode and the Vortech is white with no speed movement….just the first blue light is one. Is that normal?
