calibrate solution ?
jack
Post by jack »
how to caliberate PH and salinity and where to get the solution from ?
thanks
Re: calibrate solution ?
Here's how to calibrate pH. You can get calibration solution from fish stores, Ebay, Amazon, or any number of other places. Just look for pH 7 and pH 10 calibration solution.
Navigate to Setup -> Calibrate pH on the Reef Angel.
Put the probe in some fresh 7 pH calibration solution and let it sit until the reading stabilizes (mine is around 357).
Push the stick to the side so that OK is dark blue and Cancel is light and push the stick in.
Do the same for the pH 10 reading using fresh pH 10 calibration solution. Again, CANCEL is selected by default so be sure to bump the stick over to OK or it won't take. My 10 calibration is around 575.
I can't help on the salinity, sorry.
Here's how I calibrated salinity. I use my refractometer to get a batch of salt to 35ppt using a bottle of 35ppt calibration fluid as a reference. Then use that water to calibrate the probe. Not hard at all.
jack
Post by jack »
Thanks @colin and @inevo
But where to but the caliberation fluid from ??
My friend is coming from USA so he can get me. Its not easily available here
jack wrote:Thanks @colin and @inevo
http://www.marinedepot.com/Calibration_ ... CL-ct.html
http://www.drsfostersmith.com/product/p ... catid=4512
Amazon.com
Ebay.com
Virtually any pet store that sells saltwater fish.
Where are you from?
jack
Post by jack »
ohkieee bro thank you
i am from India here pet stores are just :(
for PH what i need to buy ? ph 7 and ph 10 ?
jack wrote:ohkieee bro thank you
Yes, 7 and 10 (or 7.01 and 10.01).
jack
Post by jack »
thank you :)
