Beginner hooking up
B-ridge75
Re: Beginner hooking up
Post by B-ridge75 »
Ok. Understanding a little better now. Still lost but I'm seeing things a little clearer
It's easier than it seems.
Reading the boards here can be confusing, but most of what goes on here is advanced stuff.
I know nothing about coding and I'm still lost when it goes to somethings, but I have to say I have helped people here too.
There have been questions asked that I knew the wizard would answer so I went through it and posted the code it gave me for that persons question.
I also let them know that I got the answer buy going thru the wizard.
Go thru the wizard and set up the code.
Load it in the unit and check to see if the ports are coming on and off the way they should by plugging in a lamp like Roberto said.
I guarantee by the time you get on the phone with Lee you will have answered 95% of your initial questions by your self.
dapg8gt
Post by dapg8gt »
You really should just try it before asking more questions that will continue to confuse yourself. There is a set up guide for the controller to plug what into what and the wizard is literally answering questions.
I think you need to take the initiative to get that basic part figured out before using inevo's time like plugging in the relay, head unit etc.
I totally agree with the people hating on reef angel saying it's super hard to use. They have not used the wizard or the controller in general. Almost every thing on my controller is done thru the wizard and what's not is just a copy and paste from someone else's code. Fwiw my tank is full of sps and I have total controlability without any coding knowledge whatsoever. Literally none.
B-ridge75
Post by B-ridge75 »
Ok everyone. 1st step is done. Just replaced old unit with the upgrade. That was simple. Hopefully everything else goes so easily. Next step. THE WIZARD
Seedlessone
Post by Seedlessone »
You are making this out to be way more hard than it is. A child could figure out the wizard. Just give it a shot. Thats half of the fun buying an RA. You will be suprised on how easy everything is. Just take a deep breath and knock it out.
Man its soo easy now a days. I started with RA before the wizard.
ReEfnWrX
Post by ReEfnWrX »
You keep going against everyone's advice. Which is making it more difficult for you. You can use the wizard without even having a reef angel... it's just an app that giv3s you options of how you setup the basic programming of the RA and 8th writes the code for you, you don't even need to touch or look at coding... and then you could upload the code if you wanted but you don't have to... just install it and tinker with it and 90%+ of your questions answered
Sent from my SM-N900V using Tapatalk
Ok, I worked with him this weekend. We made some great progress. The biggest problem and probably his biggest hesitation is that the only computer is his wife's Mac which he isn't an admin on. So we had to wait to even get the serial driver installed and get Arduino added to his Applications.
In any event, we went through the wizard, built a base config to get started and testing. We configured the wifi module which we had to do through CoolTerm. I even managed to get into his router. The problem though is despite the router being configured the port does not seem to be open, so we're going to have to figure that one out maybe with the provider.
B-ridge75
Post by B-ridge75 »
Thank you for saving me lnevo. Boy this is a tough crowd here. I never went against anyone's recommendations. I did nothing until I was told to. Once I was told exactly what to do and try I did. Ran into one problem getting a password. That was taken care of. I didn't go against anyone. I was fairly stating that I had got the nerve/courage or whatever you wanna call it to get this up and running. I had to start by taking out the old card and upgrading with the reef angel plus. Which I did. I apologize for reporting with excitement my first step of owning a reef angel. Was giving progress as far as what my next step was. Thanks for making me feel welcomed. I apologize. Didn't mean or want to offend anyone. Was just asking questions
