Wifi help
nevets9333
Wifi help
Post by nevets9333 »
I got my wifi attachment when I ordered the RA and set it up, everything was working fine. I have had it for a couple weeks. A couple of days ago it just stopped working. The green light was still a slow blink as if everything was fine, but it wouldn't let me connect from home or away anymore. I tried to set it up again through the wifi utility, but now I can't get it to work at all. It says false on the first 3 lines. What could have caused it to stop working? I haven't changed any of the settings since it was originally set up. Please help!
Re: Wifi help
Have you tried a re-boot?
nevets9333
Re: Wifi help
Do you mean just unplug and plug back in?
Re: Wifi help
Yup.
Re: Wifi help
sometimes my wifi module gets "stuck". i just unplug it from my controller and plug it back in and it works fine. doesn't happen all the time, but happens from time to time.
Christo
Re: Wifi help
Post by Christo »
binder wrote:sometimes my wifi module gets "stuck". i just unplug it from my controller and plug it back in and it works fine. doesn't happen all the time, but happens from time to time.
Yip!! Happens to me too!! Just unplug and plug it back in!!
nevets9333
Re: Wifi help
I tried that, but no luck. After 10 secs it came back to the slow blink of the green light. I go to the portal and get
Connection Status:
Unreachable Address
Re: Wifi help
Maybe the IP address changed? If you're getting slow green blinks then your connected...
