Hello, need recommendation
Re: Hello, need recommendation
And RA is still $489 vs $525. And the RA comes with 4 dimming ports as well (2 analog/pwm 0-5 or p-10v amd 2 are 0-5V which can control your jaebo powerheads) so that would drop the need for the dimming module and you could double up the kessils so you'd control both fixtures with the two remaining ports. So all you'd need now is the ra plus the wifi module. Price is now $378.
Sounding betterlnevo wrote:And RA is still $489 vs $525. And the RA comes with 4 dimming ports as well (2 analog/pwm 0-5 or p-10v amd 2 are 0-5V which can control your jaebo powerheads) so that would drop the need for the dimming module and you could double up the kessils so you'd control both fixtures with the two remaining ports. So all you'd need now is the ra plus the wifi module. Price is now $378.
The only caveat there is then you would have no inputs for your float switch. So you could either add the dimming, the single, or the multi level water sensor at a cost of $109, $69, and $159 respectively and you still wouldn't need the expansion hub yet.
