Hello everyone,
I recently bought a new RA+. I've been using it as-is with the built-in software. I'm ready to get started with coding. So I followed the instructions very carefully. Serial port is correct. Board is correct. Went to File, Sketchbook, Example Codes and selected "InitialInternalMemory." I click Upload. Everything appears to be working correctly. The upload process runs. At the end the RA status light blinks for a bit and then at the bottom of the Arduino software window it says "Error Uploading." I tried it several times with the same result. I also shut down my computer and restarted and tried again. By the way, I'm using a Mac running OS 10.6.3 (Snow Leopard).
Any help would be appreciated.
Frank
Can't upload "InitialInternalMemory"
Re: Can't upload "InitialInternalMemory"
Please see the attached file.
Frank
Frank
- Screen shot 2014-10-06 at 6.29.22 AM.jpg (109.2 KiB) Viewed 5422 times
Think theres a missing library file for this version of Mac OS. I'm sure roberto will post the answer. Sorry I forgot the name of it or I'd help search.
Someone had the same problem and I think it is because the cpu is too old.
http://forum.reefangel.com/viewtopic.php?f=2&t=2987
There is a work around in that thread but I don't think he ever tried it.
Thanks, but I got another error. When I downloaded avrdude 5.11 it had tons of files in it.
First, I removed the only one there was called "avrdude" in the Arduino folder on my mac and replaced it with all of the ones named "avrdude" in the downloaded one.
Frank
Frank
- Screen shot 2014-10-07 at 7.51.38 PM.png (51.67 KiB) Viewed 5392 times
