How to make some easy modification...
Re: How to make some easy modification...
Hmmm....That's odd that the am/pm isn't showing up. I've never seen that happen before. I think I'll have to look into that one.
I've try to install few version on different pc pc, again am/pm is not shown.
RAGen version: RAGen-v110-v08519 Installer - NO AM/PM
65 downloads RAGen-v104-v08517 Installer - NO AM/PM
System on all pc: XP
Same problem on RAGen-v1.0.0.zip — v1.0.0 - Initial Release
What is this? Should i install also this one?
vcredist_x86.exe — Microsoft Visual C++ 2005 Redistributable Libraries - required to run RAGen.
The first release needed those libraries installed. In subsequent releases, I have included the libraries with the installer. So those are not needed to be installed anymore.dhave wrote:Same problem on RAGen-v1.0.0.zip — v1.0.0 - Initial Release
The only other release you could try running would be the static library release (which has the libraries built into the actual exe file). I'm not sure if this would make much of a difference for you though.
There is any other way to change time manually somewhere, otherwise i cannot install the Ra...
You can always use the RAStatusApp that is a java application to manually set the times on the controller once the PDE file is loaded.dhave wrote:There is any other way to change time manually somewhere, otherwise i cannot install the Ra...
http://forum.reefangel.com/viewtopic.php?f=8&t=246
Downloaded and installed, but tell me "COM not implemented yet", need different version?binder wrote:You can always use the RAStatusApp that is a java application to manually set the times on the controller once the PDE file is loaded.dhave wrote:There is any other way to change time manually somewhere, otherwise i cannot install the Ra...
Maybe i need this? http://www.ftdichip.com/Drivers/VCP.htm
It's becoming hard to use this controller..
No. I have not implemented the COM port communications yet. I've only got the wifi part working with the Status app.
Sorry for the confusion.
This is arduino code of internal memory:
e.lcd_init();
e.lcd_clear(COLOR_WHITE,0,0,132,132);
e.lcd_BacklightOn();
InternalMemory.MHOnHour_write(1);
InternalMemory.MHOnMinute_write(0);
InternalMemory.MHOffHour_write(11);
InternalMemory.MHOffMinute_write(0);
InternalMemory.MHDelay_write(0);
InternalMemory.StdLightsOnHour_write(1);
InternalMemory.StdLightsOffHour_write(23);
InternalMemory.StdLightsOffMinute_write(0);
It mean...
HQI, on 01.00, off 11.00, delay 0
Neon, on 01.00, off 23.00, delay 0
Right?
So... i can change time on/off directly here, or use this to set AM/PM correctly.
e.lcd_init();
It mean...
Right?
Yes. Your understanding is correct.
You can use that to set the values. The controller only operates in 24hr mode.
Done, now time work correctly.
Now, the next problem: if i set °c display, the temperature don't work. I think the problem is the same, as long as i can set on/on point only in °f (also if i'm using °c).
InternalMemory.HeaterTempOn_write(761);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(797);
InternalMemory.ChillerTempOff_write(788);
I will set °c and change these value, right?
Yes, you can set to celsius and change those values. Should work that way.
Just one more question about the ATO setting...
I'm using two sensor:
1) sump water level, with on/off on re-fill pump
2) re-fill water tank, that should turn on a red ligh to inform me that osmotic water is nearly finished.
My problem is that I've not understand how to remove the ATO time-out on the second sensor, vause i need to keep the light on. I've try to put 0 or 600, nut nothing change, after one minute it turn off.
In future if it work, i will install an electric shutoff valve tha open/clon osmotic plant.
I'm not picturing how your setup is.
Can you explain a little better?
Is it one float switch on sump and another in water container?
Then you have an ATO pump inside this water container.
The float switch in the sump controls the ATO pump and the other does what?
Which ATO function are you using?
