Just got a reef angel
Re: Just got a reef angel
Yes I still can't upload
Let's start with the basics.
Your RA is connected to either the relay box, or USB power cable connected to a temperature port on the top and the screen is on.
The programming cable is connected to the bottom of the RA with the black wire all the way to the right. There should be an extra space on the left side of the RA.
Go to Control Panel, Devices and Printers. Look for "FT232R USB UART" (with the programming cable plugged in).
If you have multiple serial ports available under Tools in the Arduino program, try a different one.
Yes that's all correct and I only have one port to choose. I was able to upload the code that I'm currently using by using the wizard when I first set it up but now that I have change lights I wanted to change it and every time I try with the wizard I get an error uploading
Looks like there is something wrong then.
It would be either the board or the cable that is preventing this from working.
If you would like to send both of them back for analysis, send me a PM.
