You need to setup port forwarding correctly or it will be closed.
Make sure you are forwarding port 2000 to the ip address that your router assigned to the wifi attachment.
It may not be the same you have already entered in the app.
Check in the list of connected devices in your router.
Until you get this figured out, the remote access won't work.
HUUGE Favor
Re: HUUGE Favor
ok so ive tried deleting and re adding the ip/port to the port forwarding also followed the isntructions on the website posted earlier and i even got port forwarding software to do it for me and still no joy. what should i do? roberto could you do this for me?
Re: HUUGE Favor
rimai wrote:You need to setup port forwarding correctly or it will be closed.
im off work whenever you want to get started on the remote help just let me know. thanks in advance i greatly appreciate it
