HUUGE Favor
Re: HUUGE Favor
You'll need to log in to your router and verify the forwarding. If you give us your model we can help find the directions etc
vvjosh06
Re: HUUGE Favor
Post by vvjosh06 »
Net gear wndr3700
vvjosh06
Re: HUUGE Favor
Post by vvjosh06 »
How do I make the changes to the screens like those instructions say to? I went to the port forwarding menu and put the RA wifi ip address and port number and saved it. Also gave it a static ip address.
vvjosh06
Re: HUUGE Favor
Post by vvjosh06 »
Also for the actual forwarded port ip address should it start with 198? Mine starts with 198 right now.
Re: HUUGE Favor
Usually its 192.168.x.x
vvjosh06
Re: HUUGE Favor
Post by vvjosh06 »
So it should be 192 on the router?
Re: HUUGE Favor
Yea for your internal network
vvjosh06
Re: HUUGE Favor
Post by vvjosh06 »
Ok it's 192.168 on the router and the app. But still can't access from cell network or any other wifi
vvjosh06
Re: HUUGE Favor
Post by vvjosh06 »
And the port forwarding site says it's closed. How do I open?
Re: HUUGE Favor
You need to setup port forwarding correctly or it will be closed.
Make sure you are forwarding port 2000 to the ip address that your router assigned to the wifi attachment.
It may not be the same you have already entered in the app.
Check in the list of connected devices in your router.
Until you get this figured out, the remote access won't work.
vvjosh06
Re: HUUGE Favor
Post by vvjosh06 »
ok so ive tried deleting and re adding the ip/port to the port forwarding also followed the isntructions on the website posted earlier and i even got port forwarding software to do it for me and still no joy. what should i do? roberto could you do this for me?
vvjosh06
Re: HUUGE Favor
Post by vvjosh06 »
rimai wrote:You need to setup port forwarding correctly or it will be closed.
im off work whenever you want to get started on the remote help just let me know. thanks in advance i greatly appreciate it
