Cannot upload anything to the controller.
pontopnop
Post by pontopnop »
Hello,
I am trying to upload codes to my new ReefAngel Plus controller, but this is what i get:
Error uploading
"The following features were automatically added:
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 23,324 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_getsync(): timeout communicating with programmer"
I have Mac OSX, installed driver, copied everything as instructed, connecting USB/TTL cable correctly, have power on my controller, choosing correct board, tried every possible serial port, tried every USB port i have on my computer, it just does not reboot when it supposed to.
Any help appreciated.
pontopnop
Re: Cannot upload anything to the controller.
Post by pontopnop »
Is my Cable busted?
nemofordinner
Post by nemofordinner »
I am having this same issue. Emailing with Roberto will post if there is a fix.
nemofordinner
Open the case and hold the reset button. Push the upload button on your screen and when it says rebooting let go of the reset button. It's weird but worked for me. Was able to upload a few different codes but system won't reboot on its own.
estanoche
Post by estanoche »
Similar problem; solved... I was plugging my TTL cable in flush left, when you need to plug it in flush right... Black cable to outermost pin.
