can't get to step one with WIFI
danielyulkim
Post by danielyulkim »
I just got my reef angel and am trying to set up my WIFI attachment. I am using the setup wizard, and I can't seem to even connect to the attachment. I keep on getting the error message to unplug and replug the wifi attachment from the USB connector when I hit the connect button on the screen.
Any suggestions?
Re: can't get to step one with WIFI
Make sure you are using the correct COM port and that you are connecting the cable with the black wire to the right most pin.
danielyulkim
that was it. thanks!
