Does this code look correct
PostPosted: Mon Jul 20, 2015 8:21 am
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardHeater( Port1,770,785 );
    ReefAngel.StandardLights( Port3,8,0,21,0 );
    ReefAngel.StandardLights( Port4,9,0,20,0 );
    ReefAngel.WavemakerRandom( Port5,10,100 );
    ReefAngel.StandardLights( Port8,8,0,21,0 );
PostPosted: Mon Jul 20, 2015 8:43 am
It looks correct to me.
What are you trying to do and what is not working correctly?
PostPosted: Mon Jul 20, 2015 1:02 pm
I'm having problems uploading a new code. A buddy of mine came over this weekend to help and said he thinks it had to do with my laptop have USB 3.0 instead of USB 2.0 I'm pretty confused with what he was saying /trying to explain
PostPosted: Mon Jul 20, 2015 1:13 pm
Yeah. The code itself will not cause a problem uploading.
I believe USB 3.0 is backwards compatible, meaning it should work, but won't be as fast.
PostPosted: Mon Jul 20, 2015 5:57 pm
Sacohen wrote:Yeah. The code itself will not cause a problem uploading.
correct. usb 3 is backwards compatible with usb 2. it works just fine for me.
Sent from my Moto X
Return to For New Members
