Does this code look correct
Posted: Mon Jul 20, 2015 8:21 am
by adrenalinejunkie
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardHeater( Port1,770,785 );
    ReefAngel.StandardLights( Port3,8,0,21,0 );
    ReefAngel.StandardLights( Port4,9,0,20,0 );
    ReefAngel.WavemakerRandom( Port5,10,100 );
    ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
    ReefAngel.StandardLights( Port8,8,0,21,0 );
Re: Does this code look correct
Posted: Mon Jul 20, 2015 8:43 am
by Sacohen
It looks correct to me.
What are you trying to do and what is not working correctly?
Posted: Mon Jul 20, 2015 1:02 pm
by adrenalinejunkie
I'm having problems uploading a new code. A buddy of mine came over this weekend to help and said he thinks it had to do with my laptop have USB 3.0 instead of USB 2.0 I'm pretty confused with what he was saying /trying to explain
Posted: Mon Jul 20, 2015 1:13 pm
by Sacohen
Yeah. The code itself will not cause a problem uploading.
I believe USB 3.0 is backwards compatible, meaning it should work, but won't be as fast.
Posted: Mon Jul 20, 2015 5:57 pm
Sacohen wrote:Yeah. The code itself will not cause a problem uploading.
correct. usb 3 is backwards compatible with usb 2. it works just fine for me.
Sent from my Moto X
