Help With my build - PWM Expansion
PostPosted: Thu Dec 31, 2015 3:39 pm
This is were I am at atm
#include <Moon.h>
//Standard Dimming//
int ActinicPWMValue=0;    // For cloud code
int DaylightPWMValue=0;   // For cloud code
//Dimmer Expansion//
int WhitePWMValue=0;
int SupPWMValue=0;
int MoonPWMValue=0;
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddORPExpansion();  // ORP Expansion Module
    ReefAngel.FeedingModePorts = Port3Bit;
    ReefAngel.FeedingModePortsE[0] = Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit;
    ReefAngel.WaterChangePortsE[0] = Port8Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.StandardHeater( Port2 );
    ReefAngel.StandardFan( Port4 );
    ReefAngel.DayLights( Port7 );
    ReefAngel.ActinicLights( Port8 );
    ReefAngel.SingleATOHigh( Box1_Port2 );
    ReefAngel.DayLights( Box1_Port5 );
 //Display in Failsafe//
  ReefAngel.Relay.Off(Box1_Port8);
//Lighting Control//
    ActinicPWMValue=PWMSlope(5,00,21,00,15,100,180,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(6,30,18,30,15,70,180,DaylightPWMValue);
    CheckCloud();
//Lighting expansion control//
WhitePWMValue=PWMSlope(6,30,18,30,0,100,180,WhitePWMValue);
SupPWMValue=PWMSlope(6,30,18,30,0,100,240,SupPWMValue);
MoonPWMValue=PWMSlope(21,00,5,00,0,100,200,MoonPWMValue);
ReefAngel.PWM.SetChannel( 0, WhitePWMValue);
ReefAngel.PWM.SetChannel( 1, ActinicPWMValue);
ReefAngel.PWM.SetChannel( 2, SupPWMValue);
ReefAngel.PWM.SetChannel( 3, SupPWMValue);
    ReefAngel.Portal( "tyson_mitchell_88" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(6,30)
#define Lightning_Change_per_Cloud 60
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
    // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = { Calm, Calm, Calm, Slow, Slow, Slow, Slow, Slow, Mega, Mega2 };
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));    // Flash on
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
            wdt_reset();
        break;
      case Fast:
            wdt_reset();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      ReefAngel.CustomVar[3]=cloudstart/60;    // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.CustomVar[4]=cloudstart%60;    // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));    // Write the minute of the next lightning to a custom variable for the Portal
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
PostPosted: Fri Jan 01, 2016 8:19 am
Give this a try. It was major surgery. :mrgreen:
It compiles, but I can't test it otherwise. Let me know how it works.
#include <Moon.h>
int SupPWMValue=0;
int MoonPWMValue=0;
    CheckCloud();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
  byte n;
  int newdata;
  byte a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (byte i=0; i<a; i++)
    // Flash on
    analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));    // Flash on daylight port
    newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*4));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 4.
    Wire.write(0x8+(4*5));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 5.
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValue(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    Wire.write(0x8+(4*1));
    newdata=ReefAngel.PWM.GetChannelValue(4);   // Use the channel number you're flashing here
    Wire.write(0x8+(4*2));
    newdata=ReefAngel.PWM.GetChannelValue(5);   // Use the channel number you're flashing here
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
PostPosted: Fri Jan 01, 2016 8:35 pm
Loaded it up this morning, everything so far so good.
Only thing is my lcd is is staying black again. I added in InternalMemory.LCDID_write(0); to setup a while back which fixed it, but same problem again.
PostPosted: Sat Jan 02, 2016 2:02 am
My white and actinic on standard dimming haven't turned off and I haven't noticed any storm action today either.
PostPosted: Sat Jan 02, 2016 3:47 am
I just noticed a couple of things. I'll see if I can fix them tomorrow.
Not sure why the standard ports aren't dimming.
PostPosted: Sat Jan 02, 2016 3:14 pm
The standard ports will turn off, but I have to reboot the angel after off times.
PostPosted: Sat Jan 02, 2016 11:55 pm
Update, getting effects on standard nothing on expansion
PostPosted: Sun Jan 03, 2016 1:34 am
Also Current build
#include <Moon.h>
int SupPWMValue=0;
int MoonPWMValue=0;
    ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port7Bit | Port8Bit;
//boosterpump//
      ReefAngel.Relay.Off(Box1_Port2);
    MoonPWMValue=PWMSlope(21,00,5,00,0,MoonPhase(),200,MoonPWMValue);
    CheckCloud();
ReefAngel.PWM.SetChannel( 4, MoonPWMValue);
ReefAngel.PWM.SetChannel( 5, MoonPWMValue);
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
  byte n;
  int newdata;
    // Flash on
    newdata=4095;
  cstart*=60;
  cend*=60;
PostPosted: Sun Jan 03, 2016 10:30 am
Not sure why the standard ports would be staying on. You may need to reduce the minimum value in your PWM slope. Looks like it's set for 15.
This should fix the lightning.
#include <Moon.h>
int SupPWMValue=0;
int MoonPWMValue=0;
//boosterpump//
    CheckCloud();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      WhitePWMValue=DaylightPWMValue;
      MoonPWMValue=DaylightPWMValue;
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
  byte n;
  int newdata;
    // Flash on
    analogWrite(daylightPWMPin,255);    // Flash on daylight port
    newdata=4095;
  cstart*=60;
  cend*=60;
PostPosted: Sun Jan 03, 2016 12:17 pm
Just to check myself is this how the command works.
on 5, off 9, min 15, max 100, ramp 180, outside on off value(0).
thanks
Return to For New Members
