Help With my build - PWM Expansion
PostPosted: Mon Jan 04, 2016 3:48 am
Correct.
PostPosted: Sat Jan 23, 2016 5:41 am
Hi Colin, I have changed the cloud / lightning to not activate channels 4 & 5 on the expansion. Are you please able to run you eyes over just to make sure its all good?
#include <Moon.h>
//Standard Dimming//
byte ActinicPWMValue=0;    // For cloud code
byte DaylightPWMValue=0;   // For cloud code
//Dimmer Expansion//
byte WhitePWMValue=0;
byte Actinic1PWMValue=0;
byte SupPWMValue=0;
byte MoonPWMValue=0;
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddORPExpansion();  // ORP Expansion Module
    ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port6);
    ReefAngel.StandardHeater( Port2,220,225 );
    ReefAngel.StandardLights( Port3,8,00,16,00);
    ReefAngel.StandardFan   ( Port4,230,238 );
    ReefAngel.StandardLights( Port7,21,00,5,00 );
    ReefAngel.StandardLights( Port8,5,00,21,00 );
    ReefAngel.StandardLights( Box1_Port5,8,00,16,00 );
//White off
  if (hour()==18 && minute()==30 && second()>=0 && hour()==18 && minute()==30 && second()<2)
    ReefAngel.Relay.Off(Port8);
//Display in Failsafe//
      ReefAngel.Relay.Off(Box1_Port8);
//boosterpump//
      ReefAngel.Relay.Off(Box1_Port2);
//Lighting Control//
    ActinicPWMValue=PWMSlope(5,00,21,00,0,100,180,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(6,30,18,30,0,70,180,DaylightPWMValue);
    WhitePWMValue=PWMSlope(6,30,18,30,0,60,180,WhitePWMValue);
    Actinic1PWMValue=PWMSlope(5,00,21,00,0,80,180,Actinic1PWMValue);
    SupPWMValue=PWMSlope(8,00,16,00,0,80,200,SupPWMValue);
    MoonPWMValue=PWMSlope(21,00,5,00,0,30,235,0);
    CheckCloud();
//Lighting expansion control//
    ReefAngel.PWM.SetChannel( 0, WhitePWMValue);
    ReefAngel.PWM.SetChannel( 1, Actinic1PWMValue);
    ReefAngel.PWM.SetChannel( 2, SupPWMValue);
    ReefAngel.PWM.SetChannel( 3, SupPWMValue);
    ReefAngel.PWM.SetChannel( 4, MoonPWMValue);
    ReefAngel.PWM.SetChannel( 5, MoonPWMValue);
//Waterchange Mode
  static time_t wc_drain=0;
  static time_t wc_tankoff=0;
  static time_t wc_tankup=0;
  static time_t wc_refill=0;
  static int stage=0;
  if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE || (hour()==18 && minute()==0 && second()==0))
  {   // At 6pm every day the following to occur or when WC mode is activated
    wc_tankoff=now();
    stage=1;
  if (now()-wc_tankoff < 300 && stage==1)
      ReefAngel.Relay.Off(Box1_Port7);
    wc_drain=now();
    wc_tankoff=0;
//    stage=2;
//  if (now()-wc_drain < 300 && stage==2)
//    if (ReefAngel.HighATO.IsActive())
//    ReefAngel.Relay.On(Box1_Port4);
//    else
//    ReefAngel.Relay.Off(Box1_Port4);
//  } else {
//    wc_tankup=now();
//    wc_drain=0;
//    stage=3;
//  if(now()-wc_tankup < 300 && stage==3)
//    ReefAngel.Relay.On(Box1_Port7);
//    ReefAngel.Relay.On(Box1_Port8);
//  } else {
//    wc_refill=now();
//    wc_tankup=0;
//    stage=4;
// if (now()-wc_refill < 300 && stage==4)
//    ReefAngel.Relay.Off(Box1_Port1);
//    else
//    ReefAngel.Relay.On(Box1_Port1);
//    } else {
    //ButtonPress++;
//    wc_refill=0;
//    stage=0;
    ReefAngel.Portal( "tyson_mitchell_88" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(6,30)
#define Lightning_Change_per_Cloud 60
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
    // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = { Calm, Calm, Calm, Slow, Slow, Slow, Slow, Slow, Mega, Mega2 };
   static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      WhitePWMValue=DaylightPWMValue;
      MoonPWMValue=DaylightPWMValue;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      ReefAngel.CustomVar[3]=cloudstart/60;    // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.CustomVar[4]=cloudstart%60;    // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));    // Write the minute of the next lightning to a custom variable for the Portal
void Strike()
  byte n;
  int newdata;
  byte a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (byte i=0; i<a; i++)
    // Flash on
    analogWrite(daylightPWMPin,255);    // Flash on daylight port
    newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
    newdata=ReefAngel.PWM.GetChannelValue(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    Wire.write(0x8+(4*1));
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
Last edited by tyson_mitchell_88 on Sat Jan 23, 2016 5:55 am, edited 1 time in total.
PostPosted: Sat Jan 23, 2016 5:51 am
Here you go. Made one change in the Strike routine to properly de-flash channel 0.
#include <Moon.h>
byte SupPWMValue=0;
    ReefAngel.WaterChangePortsE[0] = Port7Bit | Port8Bit;
//boosterpump//
    CheckCloud();
//White off
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      //MoonPWMValue=DaylightPWMValue;
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
  byte n;
  int newdata;
    // Flash on
    newdata=4095;
  cstart*=60;
  cend*=60;
PostPosted: Sat Jan 23, 2016 5:54 am
Sweet, thanks mate
PostPosted: Sun Jan 24, 2016 2:17 pm
Hi Colin, for some reason channels 4 & 5 are still activating in storms.
PostPosted: Sun Jan 24, 2016 2:33 pm
Made an edit. Try the above code again.
PostPosted: Sun Jan 24, 2016 9:10 pm
Seems all good now, thanks again mate :)
Previous
Return to For New Members
