Some strange issues
Posted: Tue Jan 19, 2016 8:55 am
by Frogman
Good morning Reef Junkies!
I've always considered myself a geek, but this programming piece has me feeling a little skiddish and insignificant! :lol:
I'm a newbie in the RA work (RA+) and just got my system setup a week ago. I don't have any adapters or modules yet, but I will be looking to get the wireless one in Feb. When I use the wizard to code setup for my lights, I am getting some funky irregularities. I can set on and off times, but it only want to work on occasion.
My questions/issues of concern:
First, the other day the system just completely shut itself off and turned off anything attached to it. It was like it just lost power, display was dead, no power to anything in the unit. Everything I plugged into the outlet worked. I unplugged everything, put it all into a normal power bar and all my equipment was ok. I looked at the module and power box and nothing seemed to be wrong. Next morning I hooked everything back up and it has worked fine.
I unscrewed the unit and there appears to be a small singe type mark on the primary board attached to the joystick. When I plugged it back in, the display was asci characters until I re-ran the wizard and the display seemed to correct itself. I took a fine bristle brush (dry) and gently cleaned it off. So far so good. Ill keep an eye on this and send it back if it continues.
Secondly, my lighting. I am in the process of changing to LED's, but I currently have a Aqualife pro 72 MH(3x150)T5 combo. My lighting works well except for moon light (4 led's built into the system (Plug 1) and a modular LED light bar plugged into port 2. (actinics are on 2 and MH/T5 are on 4) When I put in the code for
Its not exactly right, I'm trying to do this from memory while on break at work
(Moon Lights)
StandardLights ... port1 (,5,00,9,00) ;(19,00,22,00) ;
StandardLights ... port2 (,5,45,9,00) ;(19,00,22,45) ;
etc...
The lights will turn on and off at the correct times, until Saturday, when they didn't want to come on any more in the evening. I reloaded the base program, ran the wizard and then edited the code again, it wouldn't work. (Note, this is after the unit mysteriously shut itself off.)
Do you think there is a problem with the controller?
Re: Some strange issues
Posted: Wed Jan 20, 2016 4:44 am
by cosmith71
Post your code.
Does the screen show the appropriate outlets have switched on? How many total amps does that MH/T5 fixture draw?
Posted: Mon Jan 25, 2016 6:37 am
by Frogman
Collin,
Sorry for the delay in my reply, I was helping host a Frag Swap so needless to say, its been a busy weekend.
I had ZERO power, no outlets, no RA power... Nothing.
The problem was a faulty cord. I took another cord from my computer hardware supplies and the problem disappeared..
Ill post my code later tonight when I get home.
Jeremiah
cosmith71 wrote:Post your code.
Posted: Wed Jan 27, 2016 3:59 pm
by Frogman
My Code:
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port1,5,0,10,0 );
ReefAngel.StandardLights( Port1,19,00,22,45 ) ;
ReefAngel.StandardLights( Port2,5,45,10,0 );
ReefAngel.StandardLights( Port2,19,00,22,00 ) ;
ReefAngel.StandardLights( Port3,9,55,20,30 );
ReefAngel.StandardLights( Port4,12,0,20,0 );
ReefAngel.StandardHeater( Port7,760,780 );
Posted: Thu Jan 28, 2016 4:56 am
by cosmith71
Hmmm. I'm not sure you can do two StandardLights for the same port.
Try this:
if ((hour() >= 5 && hour() < 10) || (hour() >=17 && (hour() < 22 && minute() < 45)))
  ReefAngel.Relay.On(Port1);
  ReefAngel.Relay.Off(Port1);
if (((hour() >= 5 && minute() >= 45) && hour() < 10) || (hour() >= 19 && hour() < 22))
  ReefAngel.Relay.On(Port2);
  ReefAngel.Relay.Off(Port2);
Posted: Thu Jan 28, 2016 7:54 am
by Frogman
Thanks, I will try this when I get home.
Posted: Thu Jan 28, 2016 3:38 pm
by Frogman
I am getting this error when I post the code. Its changed slightly, did I miss something?
Watchdog Timer
Version Menu
2014 Main Screen
Standard Menu
sketch_jan27a.cpp: In function 'void loop()':
sketch_jan27a:76: error: expected `)' before '{' token
sketch_jan27a:79: error: expected `)' before 'else'
Code:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
if (((hour() >= 5 && minute() >= 45) && hour() < 10) || (hour >= 19 && hour() < 22))
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.Off(Port3);
ReefAngel.StandardHeater( Port7,780,800 );
Posted: Thu Jan 28, 2016 3:43 pm
by cosmith71
Yeah, this part. You have extra parentheses. Just click "Select All" on the code I posted, copy, then paste into Arduino.
Posted: Thu Jan 28, 2016 4:34 pm
by Frogman
Same Error
***Here is where it states the error is***
Posted: Thu Jan 28, 2016 4:47 pm
by Frogman
Sorry, Like I said i am new.. Please bear with me.
I didn't realize I wasn't copying the editor
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
// This must be the first line
// Ports toggled in Feeding Mode
// Ports toggled in Water Change Mode
// Ports toggled when Lights On / Off menu entry selected
// Ports turned off when Overheat temperature exceeded
// Use T1 probe as temperature and overheat functions
// Set the Overheat temperature setting
// Ports that are always on
////// Place additional initialization code below here
////// Place additional initialization code above here
if (((hour() >= 5 && hour() < 10) || (hour() >=17 && (hour() < 22 && minute() < 45))
////// Place your custom code below here
////// Place your custom code above here
// This should always be the last line
Posted: Thu Jan 28, 2016 5:10 pm
by cosmith71
Stupid parentheses. :oops:
Posted: Thu Jan 28, 2016 5:35 pm
by Frogman
I was trying, resolved the first one, but couldn't figure out the second set.
My Wifi Controller should come tomorrow, so i might change up a little, but what you've helped me with is beginning to make sense. Hopefully I can do a little coding (sheer attempt at this point) this weekend and see what I can come up with.
Thanks again! Sincerely Appreciated!!!
