PWM output not matching schedule
rufessor
Post by rufessor »
Hi All-
This is really the first major operating code I am trying to load and it has the cloud feature in it. I have changed things to match my setup which is.
Channel 0 PWM output Rightside NW
Channel 1 PWM ouput Rightside RB
Channel 2 PWM output Leftside NW
Channel 3 PWM output Rightside RB
I have the following as my PDE, in entirety. It loads fine and when I run it I get at 10:45 pm only the left side NW lights on low and PWM output voltage at all terminals is as follows.
PWM 0= 0V
1=0V
2=3.3V
3=0V
The pde is here in its entirety. When I use a RaGEN pde FOR pwm CONTROL I get accurate dimming control over all 4 modules, the whites drop at about 23 % to flicker the Blues about 10% to flicker. So I know that my PWM controller can output all range voltage to all channels...
Oh... the controller knows the correct time if your wondering.
Also... screwing around with this a little bit I had just the left side blues on, but none of the other lights on. When I set it to run lights to 11:50 pm i.e. 23,50 everywhere and reload...
only the left side RB and NW string power on... at 4.97 V each... which is channel 2 and 3 so what happened to 0 and 1???????????
Can you help tell me why... I think the code looks ok in terms of definig the on off times but I am not absolutely certain, but I think its right. Also, this would be inconsistent with the behavior I am seeing, both NW strings are set the same for me in sunrise sunet table but only L side lights....
or none of hte right side seems to work...
channel 0 1 seems to not output no matter what I do to the inputs but I have made them the same as whats working for chanel 2 3 and that does not fix it so I am kinda lost.
// Autogenerated file by RAGen (v1.1.0.126), (01/14/2012 21:47)
// RA_011412_2147.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
#define SaveRelayState
#define PWMEXPANSION
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
  0,0,0,0,0,0};
//End of PWM Expansion Code Header
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardATO(Port1);
    ReefAngel.MHLights(Port3);
    ReefAngel.Wavemaker1(Port4);
    ReefAngel.Wavemaker2(Port5);
    ReefAngel.StandardFan(Port6);
  PWMChannel[LEDPWM0]=PWMSlope(9,00,19,30,23,50,20,PWMChannel[LEDPWM0]);
  PWMChannel[LEDPWM1]=PWMSlope(7,30,23,00,10,50,20,PWMChannel[LEDPWM1]);
  PWMChannel[LEDPWM2]=PWMSlope(9,00,19,30,23,50,20,PWMChannel[LEDPWM2]);
  PWMChannel[LEDPWM3]=PWMSlope(7,30,23,00,10,50,20,PWMChannel[LEDPWM3]);
  CheckCloud();
  PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
  PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
  PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
  PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
//  ReefAngel.LCD.DrawText(0,255,120,120,PWMChannel[LEDPWM1]);
//  ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
//  ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
//  ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(9,30)
#define Actinic_Channels B010100
#define Daylight_Channels B101000
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      for (int a=0;a<6;a++)
          PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
        for (int b=0;b<6;b++)
            else lightningstatus=0;
            if (lightningstatus) PWMChannel[b]=100;
            else PWMChannel[b]=0;
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
rufessor
Re: PWM output not matching schedule
Post by rufessor »
might have an issue with features file... checking now hold on worrying..
rufessor
Post by rufessor »
It does not seem to be that but here is current features.h file
* Copyright 2010-11 Curt Binder
* Licensed under the Apache License, Version 2.0 (the "License")
#define SIMPLE_MENU
#define wifi
#define VersionMenu
rufessor
Post by rufessor »
Oh.. more information so you dont have to look at the whole thing. I did not write any of this code really, its a RAgen PDE that I copied the cloud.pde (from a post attachment by Roberto) into. I changed the way the PWM slope is done to correspod to my times and flicker points, and I changed the lines about Actinic/daylight channels and as far as I know not much else. I copied a features.h file as the one RAgen makes pushes the files over memory limit with the cloud feature in it as has been posted before so I used the features.h file Binder posted to help someone else.
This morning at sunrise channel 2 (NW) was on at the correct time for the RB channels but only channel 2 so clearly comm to the PWM module is wrong as it was supposed to be channel 1,3 this morning and then 0,2.... seems like only 1 channel comes on... I must have done something because when I reload the RAgen PDE for PMW and LEDdisplay I can turn them all back on to light the tank today so its not hardware thats for sure :) Just me!
I can see these 2 lines need to be changed:
The binary number starts on the right and not the left.
They should be:
#define Actinic_Channels B001010
#define Daylight_Channels B000101
Try this first.
But I don't think this is the problem though.
I need to look more closely at the code.
Did you connect like in this photo?
Channel 0 is the furthest away from the +12VDC.
rufessor
Post by rufessor »
I believe i have it wrong which would explain much. Fixing now I bet code is fine but for binary issues. thanks. will post if further issues else consider it fixed I bet its this.
