clock reseting?
Posted: Thu Oct 27, 2016 6:43 pm
by shimmerlessreef
The clock keeps changing time then its saying its later or earlier than actual time. Like 6 -10 hours
Re: clock reseting?
Posted: Thu Oct 27, 2016 6:47 pm
What expansion modules do you have connected?
Sounds like a bus lock problem.
Re: clock reseting?
Posted: Thu Oct 27, 2016 7:25 pm
by shimmerlessreef
I dont have any hooked up other than the wifi exp
Re: clock reseting?
Posted: Thu Oct 27, 2016 10:56 pm
Is this a new unit you just bought?
Re: clock reseting?
Posted: Mon Oct 31, 2016 10:13 pm
by shimmerlessreef
I bought it used. I just looked and i have ato activated but nothing is plugged into the port. Could that do it?
Re: clock reseting?
Posted: Mon Oct 31, 2016 10:17 pm
You may have a bad head unit. Do you see any signs of water damage?
Re: clock reseting?
Posted: Tue Nov 01, 2016 10:32 pm
by shimmerlessreef
No but that being said i havnt taken it apart. Everything else seems to work though
Re: clock reseting?
Posted: Tue Nov 08, 2016 6:45 am
I had a loose battery terminal in mind that was causing it
