Questions before potentially buying!
PostPosted: Fri Nov 25, 2016 7:22 am
My first post!
I've been toying with the idea of getting a Reef tank controller for some time, but the 'lite' ones have very little functionality and the full blown ones are incredibly expensive. The Reef Angel I think would fit my budget! My first question is about the dimmable function. I currently do not have LED's, but I may in the future. I'm not sure which dimmable to select, digital or analog, and why. My tank will be on the first floor and the sump in the basement. I imagine this would cause a problem and I would have to run wavemaker and lighting extension cords to the controller, as everything else would be in the sump.
Thanks you,
David
PostPosted: Fri Nov 25, 2016 9:43 am
Analog and PWM are 2 different technologies of dimming.
If you are unsure of which LED technology your fixture will use, I would go with the analog as this is the most common one for LED fixtures available in the market, even though it is less precise and older technology.
Return to For New Members
