RA portal charts does not have new data
Re: RA portal charts does not have new data
When did you change the server? I mean why would all four of our controllers stop being capable of sending tho the correct server at the same time? What do you think happened?
I am also able to control the controller via portal, or via phone, or via reef angel client. My reef angel client (windows client) now has graphs up to date, but the portal is still broken back to 24th.
If it is settings in the wifi unit would I have no connection at all, or could it be 'partially broken' ?
I'll grab the settings if partial, just rather difficult to pull the unit and get it to my pc.
Output after running get e:
<4.41> get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on 131C11
SSID=WiFly-GSX-bb
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.0.150:2000
NM=255.255.255.0
GW=192.168.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=198.142.0.51
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=PumpkinPie
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=blanked for sec
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePw
While connected on COM port to the wifi module this http request response repeated over and over in console.
192.168.0.150 is my RA controller IP.
GET /r99 HTTP/1.1
Host: 192.168.0.150:2000
HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Thu, 29 Dec 2016 10:12:41 GMT
Connection: close
Content-Length: 311
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request</h2>
<hr><p>HTTP Error 400. The request is badly formed.</p>
</BODY></HTML>
GET /r99 HTTP/1.1
Update: Prior to getting the current parameters from the Wifi module I also reprogrammed it again using the macro to make sure. My charts have updated now with historical data filled in, with most recent entries being moments ago.
Thanks again rimai, I absolutely love my RA and would be crippled without it!
hi, seems like a few steps were taken that went over my head. can someone please lay the steps out for us knobs?silkjc wrote:Update: Prior to getting the current parameters from the Wifi module I also reprogrammed it again using the macro to make sure. My charts have updated now with historical data filled in, with most recent entries being moments ago.
please thanks
edit: what is a macro?
Rimai, could you please explain what happened that requires the macro excecution? What explains this? I am curious as to why the macro step needs to be excecuted. Please explain.
We changed servers a few months back and I setup a forwarding to be able to support the backward compatible wifi attachments that were pointing to the old server.
Well, obviously something happened with that service.
The best is to just update the setting of the wifi attachment using the macro so you point to the correct server.
The old server was ip address 198.171.134.6:80 as seen on the host line of the post above.
The new one and what the macro has is 104.36.18.155:80.
So, running the macro just once would fix your problem.
If it does, please let us know.
For macro instructions, follow this post:
http://forum.reefangel.com/viewtopic.php?f=3&t=4601
That is a great explanation. Thank you.
cant open the tera term file on my Mac and I don't see a file for Mac users???
Sorry, tera term is for windows only.
If you want to do it on Mac, you need to use Coolterm and there is no macro option for it.
You will need to manually type it.
Open the serial connection at 57600 baud.
Then type $$$ and it should respond with CMD.
Then type the following commands:
set i h 104.36.18.155
save
reboot
what is coolterm? and, how do I Open the serial connection at 57600 baud?
im so confused
im so confused
Click options and you should be able to change it.
There is a small tutorial here when I googled: https://learn.sparkfun.com/tutorials/te ... -mac-linux
Ran the macro and mine is up and running now!! Thanks!!! I did have a bump in the road as I was trying to do the update with my pc connected to the Head Module - doesnt work that way - ha! The minute I plugged the USB cable into the WiFi module, the terminal program did its thing and all is well. Also, it took a couple of times hitting ok before i realized the macro was looping and then what you had said to someone else - that it only had to be ran once made sense. I hit cancel and I was golden!
Again thanks Roberto for the quick reply!
thanks Roberto, assume I'm wired to the head unit as I do this? don't believe it was stated here. don't want to have my RA shut down if it doesn't work.rimai wrote:Sorry, tera term is for windows only.
Then type the following commands:Code: Select all
set i h 104.36.18.155 save reboot
thanks
No. we are programming the wifi attachment, so you have to connect to the wifi attachment.
this is bs!!!
first it won't let me type $$$ when I connect to 57600 so I copied and pasted and nothing happened......
I have wifi attachment connected to serial port and baud 57600. your instructions say to "then type $$$ and it should respond with CMD" which I cannot do. what should I do now to get this working?
thanks
thanks
Click Options
Choose the serial port connected to your wifi attachment
Choose 57600 baud rate
Click Ok
Click Connect
Type $$$
Click Ok
Click Connect
Type $$$
this is what I got after following your steps
<4.41>
not sure how to upload screenshots or pics, I'm a computer knob
<4.41>
There you go. you are in command mode.
Now type the other commands
the following is what I got. now what?
Disconn from Joshua2001,LOST-AP
Auto-Assoc Joshua2001 chan=6 mode=MIXED SCAN OK
Joining Joshua2001 now..
Associated!
DHCP: Start
DHCP in 1798ms, lease=604800s
IF=UP
DHCP=ON
IP=192.168.0.34:2000
NM=255.255.255.0
GW=192.168.0.1
Associated!
DHCP: Start
IF=UP
DHCP=ON
NM=255.255.255.0
GW=192.168.0.1
thanks Roberto but the portal still has dec 23rd as the last data for relays and web charts?
Then something went wrong.
Connect to the module again and send "get e" command.
Paste the response
Paste the response
I typed "get e" and this was the response
<h1>Bad Request</h1><h1>Bad Request (Invalid URL)</h1>
You didn't enter cmd mode.
You need to type $$$ to enter command mode or no command will be accepted
