Trouble Calibrating PH Probe
Posted: Thu May 11, 2017 11:35 am
by rodric
I didn't notice this in the forum, forgive me if its already discussed somewhere.
I calibrate the probe and get normal numbers.
Ph 7.0 531
Ph 10.0 839
After calibration, the probe does read very close to 10.0 in the 10.0 solution. Then I reboot. PH shows super low and the calibration numbers go to 0.
I have tried this with default in-memory and in-code settings.
Suggestions?
Re: Trouble Calibrating PH Probe
Posted: Thu May 11, 2017 11:40 am
Those numbers look correct values.
It only does when you reboot?
If you don't reboot, does the reading look correct?
Posted: Thu May 11, 2017 4:09 pm
by rodric
Unplugged cloud wifi
Ph 7.0 445 <OK>
Ph 10.0 757 <OK>
Ph reads 10.0
Rinse in Distilled Water
Put in tank, waited…now reading 2.69!
Went back to calibrate - reads 0
Posted: Thu May 11, 2017 4:12 pm
What happens if you place in a cup with tank water?
Posted: Thu May 11, 2017 9:18 pm
by rodric
Good call Roberto! I just did it and the PH is 7.68 and stabilizing. It didn't even dawn on me to try when I saw the calibration number show up as a 0.
Do you suspect its stray voltage? I am going to try unplugging everything then plugging them in one at time.
Posted: Thu May 11, 2017 9:25 pm
by rodric
With everything but the reef angel unplugged I'm getting the same: doesn't work in tank. Works in cup.
Posted: Fri May 12, 2017 8:40 am
That is what it looks like. Stray voltage somewhere.
Posted: Fri May 12, 2017 10:32 am
by rodric
With absolutely everything unplugged it continues though. Have you ever encountered that?
Posted: Mon May 15, 2017 4:57 pm
by rodric
Does anyone have any other suggestions? With nothing plugged in, the problem persists. What could be causing it?
Thank you,
Rodric
Posted: Mon May 15, 2017 7:46 pm
So, there is no electical part connected to any outlet?
What about the float switches?
Posted: Fri May 19, 2017 6:01 pm
by rodric
That's with absolutely nothing plugged in! I don't have float valves installed yet.
Posted: Fri May 19, 2017 6:26 pm
That doesn't make sense.
Something is grounding the water.
Are you sure you don't have any pump plugged in. Even the ones not connected to RA?
Posted: Sun May 28, 2017 1:54 pm
by rodric
That's correct, no electrical part whatsoever.
Posted: Thu Jun 01, 2017 6:17 pm
by Civics14
My temp probe goes bad and does this to me. Have you checked that?
