Relay Expansion box issues
PostPosted: Tue Aug 22, 2017 9:45 am
Hi I am new here and apologetically clueless and lost.
I have gotten things up and running with the wizard, but when I try and do anything once my relay expansion box is connected, I keep getting the following error:
RelayExpansionTester:59: error: 'class ReefAngelClass' has no member named 'OverheatShutoffPortsE'
I have a relay expansion module and an expansion hub.
Have tried various cable configurations and followed the manual but to no avail. Any help will be much appreciated.
PostPosted: Tue Aug 22, 2017 9:52 am
Did you use the wizard and tell it you had a Relay Expansion box?
The wizard will automatically include all the proper files necessary. If you did use the wizard to generate the code, could you post your full code so we can see what it says and see where the problem lies.
PostPosted: Tue Aug 22, 2017 10:06 am
Yes I used the wizard again now and having same isue.
I have the expansion hub plugged into my original relay box, and a relay expansion module bussed into the expansion hub, and the data cable running from relay expansion module to the expansion relay box.
clude <ReefAngel_Features.h>
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port4Bit;
ReefAngel.StandardLights( Port1,9,0,21,0 );
ReefAngel.StandardLights( Port2,11,0,20,0 );
ReefAngel.StandardLights( Port3,0,0,21,30 );
ReefAngel.StandardLights( Port4,0,0,21,30 );
ReefAngel.WaterLevelATO( Port6,300,88,100 );
ReefAngel.StandardHeater( Port7,244,270 );
ReefAngel.Relay.DelayedOn( Port8,3 );
PostPosted: Tue Aug 22, 2017 10:27 am
You must set at least one port on the expansion box to something instead of all unused.
PostPosted: Tue Aug 22, 2017 12:41 pm
Thank you, felling a bit dumber than I am.
Return to For New Members
