I am lost as to setup RA HELP!!!!!!!
Talk about you and your tank/equipment
PostPosted: Mon Jul 30, 2012 3:29 pm
I just now received RA + and I thing i download all codes, I have no Coding experience at all. .. I am using OX S Mountain Loin. Opened up Arduino got the following era:
Watchdog Timer
Version Menu
Simple Menu
core.a(main.cpp.o): In function `main':
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:5: undefined reference to `setup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:15: undefined reference to `loop'
UIDefaults.getUI() failed: no ComponentUI class for: com.l2fprod.common.swing.JTaskPane[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=,minimumSize=,preferredSize=]
java.lang.Error
at javax.swing.UIDefaults.getUIError(UIDefaults.java:712)
at javax.swing.MultiUIDefaults.getUIError(MultiUIDefaults.java:133)
at javax.swing.UIDefaults.getUI(UIDefaults.java:742)
at javax.swing.UIManager.getUI(UIManager.java:1001)
at com.l2fprod.common.swing.plaf.LookAndFeelAddons.getUI(LookAndFeelAddons.java:270)
at com.l2fprod.common.swing.JTaskPane.updateUI(JTaskPane.java:121)
at com.l2fprod.common.swing.JTaskPane.<init>(JTaskPane.java:111)
at com.reefangel.tool.Wizard.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:682)
at java.awt.EventQueue.access$000(EventQueue.java:85)
at java.awt.EventQueue$1.run(EventQueue.java:643)
at java.awt.EventQueue$1.run(EventQueue.java:641)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:652)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.l2fprod.common.swing.plaf.LookAndFeelAddons.getUI(LookAndFeelAddons.java:275)
Please help!!!! :?
PostPosted: Mon Jul 30, 2012 4:22 pm
viewtopic.php?f=19&t=1579&p=12266#p12266
Return to You and your tank
